Noise from tranny when engaging clutch - JeepForum.com
post #1 of 5 Old 09-09-2013, 09:36 PM Thread Starter
brozonis
I have 93 yj 2.5 5spd. Recently replaced transmission(rebuilt ax5) new pressure plate and throwout bearing (autozone). Noise seems to happen mostly above 45mph. When I push in my clutch pedal at these speeds I hear almost sounds like a growling noise. But once I shift gears and let out the clutch it stops. Another thing that is confusing is if I push in the clutch at highway speeds put it in neuatral and release clutch sound still is there until I put it in gear again. Any help on this?
brozonis is offline
post #2 of 5 Old 09-09-2013, 09:39 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Sounds like the rear main bearing in the transmission.
Are you sure it's rebuilt?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 5 Old 09-09-2013, 09:47 PM Thread Starter
brozonis
Ya positve. Has a year warranty on it.
brozonis is offline
post #4 of 5 Old 09-09-2013, 09:57 PM Thread Starter
brozonis
Anyway to check it and also could it possibly be the throwout bearning?
brozonis is offline
post #5 of 5 Old 09-10-2013, 06:10 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Typically, throwout bearings make noise idling in Neutral, and not touching the clutch pedal. Slight clutch pedal pressure usually makes the noise dissipate. Additionally, they aren't usually audible at road speed.
Max
Mean Max is offline
