NOISE in 5th gear, spreading to other gears. - JeepForum.com
post #1 of 4 Old 06-03-2012, 07:05 PM Thread Starter
mrbriteside1465
I've looked around for threads on this and I can't seem to find anyone with the exact same situation.
So this morning I was cruising on the highway in 5th, and started hearing a terrible sound. I'd describe it like this: put a bunch of bolts in a plastic tupperwear container and shake it around. I didn't loose the functionality of the gear, but that noise clearly is not right. I downshifted to 4th and was able to get where I needed to go...slowly. I tried putting it back into 5th just for fun, and the sound is still there, but it is interesting to me that the gear is still functional.
Has anybody experienced anything like this? I have a pretty limited amount of tools in my garage, but I like to avoid mechanics as much as possible. If I was going to take a guess at the issue, I'd guess that maybe one of the connecting pins within the gear has broken and is rattling around? I feel like this might be a very time consuming fix, but it might be worth it because I can see an auto shop charging a ton for something like this. I honestly can't afford anything over like $2-300 right now.
Thanks in advance,
Sean
As an update to this, I was driving around town tonight and started hearing noise in my other gears as well. Not nearly as bad as 5th gear, but definitely not good.
mrbriteside1465 is offline
post #2 of 4 Old 06-03-2012, 07:06 PM Thread Starter
mrbriteside1465
1994 jeep wrangler by the way...about 160,000 miles
post #3 of 4 Old 06-03-2012, 07:28 PM
WindsorRenegade
I have summoned MeanMax for you. His graciousness will hopefully be here shortly.
Good luck!
Originally Posted by ruthole View Post
I just bumped it around till it was in the hole and she went right in. But my hands were hard to fit in there.
WindsorRenegade is offline
post #4 of 4 Old 06-03-2012, 09:28 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Sorry for the delay. My daughters were playing on my phone, so I was away for a bit. They're the reason I live, so I try to make them feel special!
What motor & transmission are we talking about?
Any change when the clutch pedal is depressed?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
5th gear , transmission
4.0L TJ grinding noise in 1st gear. Ituen Engines & Drivetrain 0 03-20-2011 04:04 AM
same gear ration need to re shim if replacing gears emahan01 Engines & Drivetrain 3 09-23-2009 09:56 PM
gear noise after shifting from 4lo to 4hi a2wheelerte Engines & Drivetrain 3 06-26-2009 10:57 PM
95' Yj Rear Differential 43 Teeth Ring Gear 14 Teeth Pinion Gear What Gears Do I Have yzman720 Engines & Drivetrain 1 06-26-2009 10:13 AM
Yukon gears Vs. genuine gear Elohim1 General Jeep & Off-Road Equipment 3 02-24-2005 06:24 AM
