No spark - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > No spark
RIGID LED Light Blowout Sale - All Sizes, All Series, all Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerraiWinter & Offroad Tires
Unread 11-18-2014, 04:32 AM   #1
nhbiker
No spark
I have a 1989 Wrangler with a 1995 2.5L the engine just quit and I have replaced the crank sensor, the coil, the wires, the plugs, the cap the rotor and the pick up in the distributor and still have no spark to the plugs. Anyone have any other ideas for me to try. Its driving me nuts
nhbiker is offline   Reply With Quote Quick reply to this message
Unread 11-18-2014, 05:56 PM   #2
jnicewan
Do you have power to the coil? Can you tell if the fuel pump comes on when cycling the key on? Did you check the ASD relay in under hood fuse box? You can swap it for another relay for a quick check, also check fuses while your in the fuse box.
jnicewan is offline   Reply With Quote Quick reply to this message
Unread 11-18-2014, 07:14 PM   #3
nhbiker
No power to the coil, fuel pump does cycle and I HAVE SWAPPED THE RELAYS AROUND AND HAVE CHECKED ALL THE FUSES UNDER THE HOOD AND UNDER THE DASH.
Unread 11-21-2014, 08:41 PM   #4
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Weren't these older YJ susceptible to bad ignition modules?
"Taking care of our veterans is a cost of war. If you can spend six trillion dollars sending people to war, you can spend a few billion dollars taking care of them when they come home"
Sen. Bernie Sanders (I-Vt.)
If what doesn't kill you, makes you stronger, I should be able to bench press a Grand Cherokee by now!
laybackman is offline   Reply With Quote Quick reply to this message
