No spark!!! - JeepForum.com
post #1 of 5 Old 06-06-2013, 05:37 PM Thread Starter
bigtom89
No spark!!!
Ok guys,
1988 Jeep YJ with a 4.2 that's been nuttered. 3 weeks ago I hit an exposed manhole that cause me to lose all power in the Jeep. I have replaces the fuseable links, ICM, coil and complete distributor and still no spark. The motor turns over but still no spark. I have pulled every fuse to make it was still good. Any suggestions, or ways to direct wire it?
1988 Wrangler YJ, 4"lift on 33" BFG Mud Terrians
bigtom89 is offline
post #2 of 5 Old 08-06-2013, 05:33 AM
123YJ
Originally Posted by bigtom89
Ok guys,
Dealing with similar problem (ie: randomly stalling out, will crank over but not fire up...and it's progressively getting worse). Replaced coil since I was getting no spark out of coil but still having 12 volts going to the coil. Negative lead to coil shows 35 ohms. My research indicates a bad ICM. Some have shared they bought a bad new ICM and replaced it several times.
I'm now looking into the HEI distributer, which eliminates the external ICM & coil.
123YJ is offline
post #3 of 5 Old 08-06-2013, 06:12 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Get an HEI. They run so much better with it.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #4 of 5 Old 08-06-2013, 09:36 AM
123YJ
Cruiser54,
Just ordered a CRT Performance HEI for my '89 4.2L I-6 an hour ago. Hopefully this will solve the problem.
Thanks for the suggestion.
Rick
123YJ is offline
post #5 of 5 Old 08-06-2013, 05:47 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Cruiser54,
Rick
You will not be disappointed.
4.2 liter , coil , ignition , spark , YJ
