no power at highway speed - JeepForum.com
post #1 of 3 Old 07-12-2007, 03:05 PM Thread Starter
Perry D
Getting wifes old 1994 Grand Cherokee 4 L ready for daughter, new driver, wife never drove on highway ever, now after doing some minor work, I go for test drive and found Jeep to be low on power on highway, struggles to get 70 kph. In the city the Jeep runs fine. Any help or ideas greatly appreciated.
Perry D is offline
post #2 of 3 Old 07-17-2007, 06:03 PM
happydog
May be fouled up spark plugs. Take it on the highway and drive it at seventy for a few miles and see if that fixes it.
happydog is offline
post #3 of 3 Old 07-20-2007, 10:49 PM
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
My kids cherokee did the same thing, ran ok at lower speeds but ran crappy at higher rpms. His sputtered when you released the pedal also. It ended up being the Throttle position sensor. It ran like a new engine after replacing it.
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline
want more speed and power!! wrangler10 Street Jeep Forum 14 07-02-2012 12:56 AM
MT/Rs and highway use DME Tires & Wheels 17 09-20-2010 08:20 AM
adjustable speed for power window motor Arbslikewhoa Audio, CB & Ham Radios, GPS, & Electrical 9 12-24-2008 03:45 PM
Highway Speed Problem wmtitan024 Engines & Drivetrain 5 09-26-2008 10:27 PM
highway with MT/R DeathCrush Tires & Wheels 5 01-05-2003 02:27 AM
