no gap on spark plug - JeepForum.com
post #1 of 18 Old 11-17-2011, 09:30 AM Thread Starter
4x4Jeep
just bought some plugs for my jeep and one of them has no gap at all
don't want to break it, but can i take some pliers and open it up or should i return it?
Build -
SOLD
4x4Jeep is offline
post #2 of 18 Old 11-17-2011, 09:35 AM
ajmorell
ajmorell's Avatar
You can try to open it up, I would just run it back to the place you bought it from and get another one so I didn't risk bending the electrode
ajmorell is offline
post #3 of 18 Old 11-17-2011, 10:37 AM
mdm
Farm Wheeler
Originally Posted by ajmorell View Post
...I would just run it back to the place you bought it from and get another one so I didn't risk bending the electrode
Really?
Just set the gap to the proper setting and put them in.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #4 of 18 Old 11-17-2011, 10:52 AM
ajmorell
ajmorell's Avatar
Yes, really. I've got plugs like that before and tried to fix them and completely mangled the electrode trying to get it gapped right.
ajmorell is offline
post #5 of 18 Old 11-17-2011, 11:43 AM
mdm
Farm Wheeler
What were you using to set the gap? It's pretty simple.
mdm is offline
post #6 of 18 Old 11-17-2011, 12:55 PM
ajmorell
ajmorell's Avatar
It wasn't an issue of setting the gap. It was an issue of bending the electrode back so that it could be gapped to begin with.
ajmorell is offline
post #7 of 18 Old 11-17-2011, 01:52 PM
mdm
Farm Wheeler
That shouldn't be a problem.
mdm is offline
post #8 of 18 Old 11-17-2011, 02:14 PM
ajmorell
ajmorell's Avatar
I agree, it shouldn't but when I tried to bend it back it mangled the electrode all to hell. I don't know why, maybe it was a fluke thing, the electodes are soft enough metal they should bend easily. It was one of those things where I just felt better spending another $1 to know it was right even though I probably could've run it the way it was.
ajmorell is offline
post #9 of 18 Old 11-17-2011, 02:39 PM
mdm
Farm Wheeler
What were you using?
mdm is offline
post #10 of 18 Old 11-17-2011, 02:42 PM
1HouseMouse
Excellent example of a mass produce item. Check everything every time and assume nothing.
1HouseMouse is offline
post #11 of 18 Old 11-17-2011, 03:00 PM
ajmorell
ajmorell's Avatar
I think I originally used a pair of needle nose pliers to bend the electrode (I'm talking about the ground electrode, not the center electrode) back a bit, then I used your standard plug gapping tool, but like I said, I mangled the ground electrode somewhere along the way. I'm not saying they can't be bent back without success, just that I f'ed one up trying.
ajmorell is offline
post #12 of 18 Old 11-17-2011, 09:37 PM
jnicewan
The better spark plug gap tools actually have a recess to spread the electrode out BTW. I would assume at some point the spark plug was dropped. Just gap it back out to spec, maybe note what cylinder you put the bent on in just in case you have a misfire (nevermind you said all of them were bent) Worst case is if it was dropped it could have damaged the plug or cracked the porcelain.
jnicewan is offline
post #13 of 18 Old 11-18-2011, 01:02 AM
NonRubicon
Originally Posted by jnicewan View Post
I would assume at some point the spark plug was dropped....Worst case is if it was dropped it could have damaged the plug or cracked the porcelain.
This.
I would exchange it for a plug with some sort of gap.
NonRubicon is offline
post #14 of 18 Old 11-18-2011, 08:14 AM Thread Starter
4x4Jeep
Originally Posted by NonRubicon View Post
This.
yea, i'll go do this. i wouldn't know how much to gap it anyway.
Build -
SOLD
4x4Jeep is offline
post #15 of 18 Old 11-18-2011, 12:07 PM
ajmorell
ajmorell's Avatar
There should be a sticker under the hood (it was on the fan shroud in my ZJ) that says the stock plug p/n and gap
ajmorell is offline
Spark Plug Color D3f4ult Engines & Drivetrain 6 05-10-2011 09:12 AM
4.0L Spark Plug Dilemma gmcd Engines & Drivetrain 7 08-12-2009 08:14 PM
spark plug trouble scotth Engines & Drivetrain 2 04-17-2007 09:08 PM
spark plug change 01jeepgrand Audio, CB & Ham Radios, GPS, & Electrical 3 08-22-2005 06:46 PM
spark plug gap badams Engines & Drivetrain 5 07-20-2002 07:59 AM
