No forward power - JeepForum.com
post #1 of 4 Old 07-15-2010, 08:34 PM Thread Starter
KloppWJ
No forward power
I have a 99 WJ with the 4.0 liter. When the vehicle is put into drive or 1st gear the jeep doesnt move. When you give it gas the engine revs to about 2500 rpms before moving. Then it feels like a 3rd gear start on a manual would feel. Reverse works fine. It sounds like a torque convertor but them I would think reverse would be shot as well. The fluid is nice and pink and doesn't smell burnt. Any ideas?
KloppWJ is offline
post #2 of 4 Old 07-15-2010, 08:42 PM
Obnoxious1
1981 CJ5
check to see if the vacuum line got knocked off your modulator valve on the side of the tranny. Also try replacing the modulator valve.
Hopefully it's that simple
Jeep –noun (jēp)
A Four wheel mechanized device surrounded by glass and metal designed for the frequent consumption of the owner/operator's money. Jeeps are also linked to diseases such as Jeep envy which can be diagnosed by unusual urges for items such as bigger tires,lift kits, shocks and AMC 401s. As well as the urge to pour money into more than one Jeep. Side effects may be spouse accruing numerous "honey-do's", as well as trips to inlaws. Grease under your nails, numerous trips to NAPA and junk yards, and spare parts in the attic may indicate an addiction. There are no known cures. However there are support groups such as JeepForum.com
Obnoxious1 is offline
post #3 of 4 Old 07-15-2010, 08:49 PM Thread Starter
KloppWJ
I'll look into that. Any other ideas if thats not it.
KloppWJ is offline
post #4 of 4 Old 07-16-2010, 10:35 AM
EricYoung
Nope, it probably is a problem with your modulator valve
EricYoung is offline
excessive revving , torque converter , tranny , tranny slipping , transmission , wj
Moving sound bar forward on a TJ wmeyer116 Cheap Tricks & Fixes 15 03-24-2011 10:15 AM
Dan DuBose is departing from BTF. Jason Carner is taking things forward. BlueTorch Fabrication Shop 2 09-29-2009 06:24 PM
U connect voice is in fast forward mode BOBBY263052 Audio, CB & Ham Radios, GPS, & Electrical 2 09-26-2009 08:02 AM
loud clunk in reverse and in forward gears S.C.JEEPER Engines & Drivetrain 1 08-07-2008 06:47 PM
Moving Factory Sound Bar Forward? JeepZen Audio, CB & Ham Radios, GPS, & Electrical 6 11-06-2002 06:44 AM
