No engine power, off & on acceleration, stalls out - JeepForum.com
post #1 of 7 Old 10-28-2008, 07:19 AM Thread Starter
richbrooks11
I have a 97 Jeep Wrangler with the 4cyl engine. It had been running mint and then last week it started acting a little "weird". Its tough to explain but it almost seems like it doesn't have the full power. I step on the gas and it has some acceleration and then none, and it does it in 1st-3rd gear because i can't get going enough to get it into 4 or 5.Also if i don't stay on the gas it dies? The check engine light has come on, but isn't flashing. I would greatly appreciate an advice from anyone. Thanks
richbrooks11 is offline
post #2 of 7 Old 10-29-2008, 02:05 AM
RIoffroad
you could have a vacuum leak or th fuel injectors could be clogged up. next time you fill the tank buy a bottle of fuel injecter cleaner, put it in the tank after you fill up and see if that makes a difference. and look under the hood for a hose that might be cracked. i would also check to see if you have goo compression in all the cylinders.
hope this helps some
RIoffroad is offline
post #3 of 7 Old 10-29-2008, 02:07 AM
famous1688
1989 XJ Cherokee
sea-foam it and call it good...
4.5in RE superflex lift, 32's, custom bumpers under construction...
famous1688 is offline
post #4 of 7 Old 10-29-2008, 06:55 AM
MIPLAYSTATION
2006 WK
Catalytic is fowled!!!
my 2003 Chevy Impala had the same symptoms and the catalytic was the culprit!!!
MIPLAYSTATION is offline
post #5 of 7 Old 10-29-2008, 11:24 PM
sootyjeep
2006 KJ Liberty
check fuel pressure under all conditions and exhaust backpressure
Fuel 45psi
Exh less than 5psi
The only replacement for displacement is Positive Manifold Pressure.
sootyjeep is offline
post #6 of 7 Old 10-31-2008, 06:15 PM
BigTDog
Fuel filter?
BigTDog is offline
post #7 of 7 Old 10-31-2008, 09:09 PM
willness33
I'm gonna vote for a plugged cat as well.
willness33 is offline
Heres one. Key CB Mic and engine stalls 92 Green YJ Audio, CB & Ham Radios, GPS, & Electrical 15 07-23-2015 07:14 PM
Engine stalls while idling GlennG Engines & Drivetrain 5 01-05-2012 09:40 AM
Jeep TJ getting no power and no acceleration enzosf General Jeep & Off-Road Equipment 1 10-18-2009 04:49 PM
Engine almost stalls after each start. tarilas10 Engines & Drivetrain 1 10-09-2008 09:05 PM
Engine bogs on acceleration alexrule123 Street Jeep Forum 23 09-12-2006 01:08 AM
