no brakes - JeepForum.com
post #1 of 11 Old 05-21-2012, 10:05 PM Thread Starter
muddy95cherokee
no brakes
I have a 95 cherokee. Recently my pedal just went to the floor upon brake application. There is no fluid loss, but yet the brakes don't work. My carpets aren't wet, and one caliper decided to grab and not let go. Since this happened I replaced master cylinder, and both front calipers, and bled the brakes. It didn't help one bit except now the calipers don't lock up.... They just don't do anything. Any thoughts on what it could be?
muddy95cherokee is offline
post #2 of 11 Old 05-21-2012, 10:26 PM
rlongsr
1987 YJ Wrangler
Did you bench bleed the master cylinder? Also, when you replace one, you should bleed all four corners, starting with the one in the back furthest away from the master cylinder first, then work your way to the front. Hope this helps!
rlongsr is offline
post #3 of 11 Old 05-21-2012, 10:29 PM Thread Starter
muddy95cherokee
I didn't bench bleed the master, but I did bleed all four starting at the wheel farthest from master cylinder
post #4 of 11 Old 05-21-2012, 10:33 PM
rlongsr
1987 YJ Wrangler
Did you get straight fluid from each line?
rlongsr is offline
post #5 of 11 Old 05-21-2012, 10:38 PM
rlongsr
1987 YJ Wrangler
Also, did you get a new master cylinder?
rlongsr is offline
post #6 of 11 Old 05-21-2012, 10:41 PM Thread Starter
muddy95cherokee
Yes straight fluid from each line and its a reman master. Came with no resivior.had to use old res
post #7 of 11 Old 05-21-2012, 10:49 PM
rlongsr
1987 YJ Wrangler
Very odd. Is someone helping you bleed the brakes? You should hear the brakes working on the back, and should be able to see the calipers working. The only other thing I could suggest is visually check all the lines, and pull the rear drums and look for a leaky cylinder. Other than that, maybe on of the other fellas on her may have some suggestions..good luck,
rlongsr is offline
post #8 of 11 Old 05-22-2012, 08:53 AM
obfdcherokee
Does it have abs?
obfdcherokee is offline
post #9 of 11 Old 05-22-2012, 03:00 PM
cherokeeman87
Did you check the brake boost.
cherokeeman87 is offline
post #10 of 11 Old 05-22-2012, 04:33 PM
Ryman12
make sure your calipers are on the right side. The bleeder valve should be above where the hose bolts on. I've made this mistake before, it was a bit embarrassing.
2000 4.0 wrangler 2.5" lift
5 speed JCR Off Road prerunner bumper
Ryman12 is offline
post #11 of 11 Old 05-23-2012, 10:55 AM
DerMeister
Yep...bleeders on top.
DerMeister is offline
