No balls - JeepForum.com
post #1 of 6 Old 07-08-2013, 01:35 PM Thread Starter
caiha
No balls
I have 09 JK 2 in lift with 35 and on the hwy it had no balls. I hit a little incline and loose all power and I am usually at 3k Rpms. Do I need diff gears
caiha is offline
post #2 of 6 Old 07-08-2013, 05:07 PM
DaemonForce
I only have that problem with a tired engine and high 2.73 gears. I'm pretty sure this would disappear with 3.08 gears but then again, I need a new engine first. With a 2009 JK there is no way you have that issue so I'm going to say lower gears will help. What do you currently have?
DaemonForce is offline
post #3 of 6 Old 07-08-2013, 05:10 PM
rambo3489
Yea. My buddy had an 09 with 35's then did gears. It helped him but not nearly as much as he thought. He has the auto and should have gone with 5.38's. He did 5.13's. Either way its going to suck for you because your 4 speed is only a 3 speed because your not using OD.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #4 of 6 Old 07-08-2013, 05:15 PM Thread Starter
caiha
About how much to regear both axles????
caiha is offline
post #5 of 6 Old 07-08-2013, 07:19 PM
DaemonForce
Rubicon or not I'm pretty sure you're moving on a pair of DANA 44's. Anything over 4.88 sounds completely insane to me but then again I have no idea what you actually do or what low gear system you work with(as well as all of them being completely foreign to me). If you're going to install a new 5.13 gearing it's about $258 for the rear and $235 in the front. I have no idea what labor would be if you're actually into paying others to work on your vehicle.
post #6 of 6 Old 07-08-2013, 08:32 PM
rambo3489
$1000- $1500 depends on where you go and how much they charge
<a href="
THE YJ MY WAY</a>
