Quantcast new temp gauge - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > new temp gauge
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 11-23-2005, 03:49 PM   #1
mike4089
new temp gauge
i bought a set of three gauges...already install the oil pressure and volt gauge....i want to install the temp gauge however the temp sensor on the end of the gauge will not fit in the top of the head where the facotry one goes.....is there another place i can install this gauge i cant exactly take them back as the other gauges have been installed and it would suck to take the oil out of the hose for the oil pressure gauge.....can i tie the sensor into the radiator hose????....would that give me an accurate reading?????????
mike4089 is offline   Reply With Quote
Old 11-23-2005, 04:32 PM   #2
98JEEPTJ
2005 WK
Well if its not to far off try cleaning the threads or you could tap it for the newer size.
OUT WITH THE OLD R.I.P. 98 TJ Sport 4" Procomp lift/adjustable lower control arms and track bar **** Cepek FCII 33x12.50x15/**** Cepek DC-1 wheels
IN WITH THE NEW 05 WK LIMITED EDITION 5.7L
98JEEPTJ is offline   Reply With Quote
Old 11-23-2005, 07:39 PM   #3
89YJmoneypit
KMG365
89YJmoneypit's Avatar
http://www.jeepforum.com/forum/f12/temp-sensor-208690/
Try this
89 YJ
Transplanted '99 4.0, AX-15, NP231
Red Jeep club #8
97 ZJ Laredo
4.0, 42re, NP242
Was my daily driver, now son's college partywagon.
89YJmoneypit is offline   Reply With Quote
Old 11-24-2005, 09:07 AM   #4
mike4089
i dont think i fully understand the tee fitting.....actually i understand it....but did you put it in the radiator hose?????.....the one that goes into the radiator not the one that goes out of the radiator....that is what i was thinking of doing but i wasnt sure if it was going to work...
Old 11-24-2005, 11:22 AM   #5
89YJmoneypit
KMG365
You put it in the small hose that goes from the water outlet to the heater core.
89 YJ
Red Jeep club #8
97 ZJ Laredo
4.0, 42re, NP242
Glock Forum
