New Jeeper - JeepForum.com
post #1 of 9 Old 12-22-2012, 04:57 PM Thread Starter
woodyracer
New Jeeper
Just got my daughter a 1995 Jeep wrangler the 4.0 HO motor has a knock when it starts and higher rpm. The motor has 235k on it. I want to replace it before she blows! Can I use any 4.0 jeep motor?
woodyracer is offline
post #2 of 9 Old 12-23-2012, 01:39 AM
hypernoodle
As long as you reuse the accessories and the valve cover, you should be good. Just make sure it has the same belt routing.
hypernoodle is offline
post #3 of 9 Old 12-23-2012, 04:15 PM
jokerchief462
Try and get something close to the same year. They only made them for a few applications so the basic block and cylinder heads should be very much the same. The brackets on the sides are the main concern but if you ask at a machine shop or junkyard they should have some info for you.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 9 Old 12-25-2012, 08:42 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
What brand of oil filter is on that 4.0? Oil pressure readings on the gauge?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #5 of 9 Old 12-25-2012, 05:35 PM Thread Starter
woodyracer
Has a fram not sure weight oil and runs 15lbs when warm 40+ when cold Thanks
post #6 of 9 Old 12-25-2012, 05:49 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Try this. Remove the Fram filter, leaving the present oil in it if it's fairly clean, and put a Wix or Napa Gold filter on it. See what happens.
post #7 of 9 Old 12-25-2012, 06:40 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Fram = complete junk.
Do as already suggested and change it out with a good filter.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #8 of 9 Old 12-25-2012, 06:49 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Martin
F*R*A*M= Forever*Ruining*Automotive*Motors.
post #9 of 9 Old 12-25-2012, 09:10 PM
leftlanetruckin
XJ on 37's
Love it, and unfortunately too true!
Martin
