New to the forum got a transfer problem - JeepForum.com
post #1 of 3 Old 10-13-2013, 02:07 PM Thread Starter
Cocacola808
1983 CJ7
I have an 83 cj7 all stock right now
It has a t5 trany and a Dana 300 transfer
The problem is the transfer won't engage if I start the jeep
It knocks bad push in the clutch and it stops the t5 shifts but the dana300
Is like it is in between gears and when you try to shift the transfer
Just won't move and when it finally does go in gear it jumps out in about two seconds tryed a few things but nothing yet
I bought the jeep from a friend that had it parked in his garage for 5 years
He parked it thinking he was going to build his dream the it just sat there
The body and frame are rot free
Only surface rust needed a new fuel pump
I bought it for 800 plates in storage
Took about half hour to get it running but can't drive do to the transfer not engaging in any gear
Any help would be great thank you
Cocacola808 is offline
post #2 of 3 Old 11-07-2013, 02:02 PM
Palmetto
Palmetto's Avatar
1981 CJ7
What exactly is going on?
So if your trans is in neutral you still can't engage the xfer case if the engine is running?
ΜΟΛΩΝ ΛΑΒΕ!
Do your duty in all things. You cannot do more, you should never wish to do less.
Robert E. Lee
Groups
Originally Posted by DiabloYJ View Post
It's a Jeep thing, I don't even understand it sometimes.
1981 CJ-7, AMC 360 bored .30 over, Edelbrock Intake, Edelbrock Cam, Edelbrock Double Roller Timing Chain, Holly 650 truck avenger carb, Flowcooler water pump. '97 Dodge 4wd Std NV4500. D300 Twin Sticked. Corbeau Seats, Custom Dash with Autometer guages, Electronic Speedo, all stainless hardware, Outlaw II Wheels, BFG AT 33" Tires, Flex-A-Lite Dual Electric Fan, AGR steering box, Borgeson steering shaft, ididit tilt column, Mean Green Starter, Tuffy console, poly gas tank, handmade rear bumper, cheap radio and speakers.
2000 XJ - HO 4.0L, 245/75R16 Goodyear Wrangler Duratracs. PSC gearbox. IRO Double Shear Trackbar. New headliner. IRO Hack & Tap SYE. IRO adjustable UCA & LCA, RE 3.5" lift, Bilstein 5100 shocks, JKS Quick Disconnects. Future mod: OTK steering, lockers, FIPK, rock sliders, JCR Bumpers, rear storage, high pinion rear (3.55), frame reinforcement, hood louvers, rack lighting.
Palmetto is offline
post #3 of 3 Old 11-07-2013, 02:06 PM Thread Starter
Cocacola808
1983 CJ7
Got frustrated put in a nouther d300 only to find the problem was trany broken main shaft was a t5 just put in a t176 much better now
