New engine wont start! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > New engine wont start!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 08-01-2015, 10:17 AM   #1
KeegFed80
I have a 98 wrangler TJ with the 4 cylinder engine. We went to replace it with a new engine of the exact same size. Everything went without a hitch until I turned the key and nothing happened. There is no sound or reaction when I turn the key. I've replaced the starter and relay and ignition switch. I think I've narrowed it down to a bad ground wire but I'm not sure where all the grounds should go and I'm a terrible electrician. Anything can help. Thanks
KeegFed80 is offline   Reply With Quote Quick reply to this message
Unread 08-01-2015, 02:08 PM   #2
Feetwet
Enjoying the Ride
Feetwet's Avatar
Interesting first post.
You can swap out an engine but when it comes to troubleshooting you just throw parts at it?
Obvious hit and run is obvious....
Fight Crime...Shoot Back
Friends don't let friends roll over without a negative-G strap
Feetwet's Ford 8.8 Axle Teardown/Rebuild/Install
AX5 Output Shaft Seal Replacement
Hand Throttle Install
AX5 Vent Install
Feetwet is offline   Reply With Quote Quick reply to this message
Unread 08-01-2015, 05:04 PM   #3
KeegFed80
I'll be honest that's exactly what I did and now I'm stuck. I just need some help.
Unread 08-02-2015, 09:24 AM   #4
greenmachine99
You've definitely got something electrical wrong. Are you getting power anywhere? Is the cluster coming to life when you turn the key to run? This could be something as simple as a bad battery connection. I'd check there first just to eliminate the simple stuff first. I bet you either missed a ground, or have a bad ground connection. Double check and clean them all.
greenmachine99 is offline   Reply With Quote Quick reply to this message
