new engine ignition problems - JeepForum.com
post #1 of 2 Old 03-23-2005, 09:29 PM Thread Starter
klamath offroad
I recently installed a new '84 amc 360 with an electronic ignition, and when I went to fire it up it was only hitting on 8, 2, 3, 5. Header pipes 1, 4, 6, 7 were stone cold. I did the wiring myself with Painless, and followed the manual to the best of my knowledge. Has this happened to anyone else?
Joel
klamath offroad is offline
post #2 of 2 Old 03-24-2005, 10:22 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I would check to make sure you have spark(which I believe you do) and that your HEI is set and timed properly. If you look at your stock intake manifold, you will see that 8,2,3,5 are run from one barrel of the carb, while 1,4,6, and 7 run from the other. I would check to see if there was a carb problem.
jeepdaddy2000 is offline
Check engine light on when removing key from ignition fumes323 Audio, CB & Ham Radios, GPS, & Electrical 0 01-17-2010 01:14 PM
problems with ignition jkl9964 Engines & Drivetrain 2 10-12-2009 12:30 PM
ignition switch problems Budlight Audio, CB & Ham Radios, GPS, & Electrical 3 02-25-2009 07:03 AM
DUI Ignition Rewire-Engine Will Idle But Thats It!! HarmonatorsCJ7 Audio, CB & Ham Radios, GPS, & Electrical 2 10-20-2008 02:21 PM
engine swap ignition trouble.... HELP! '79 CJ-7 Levi Engines & Drivetrain 1 06-28-2002 05:12 PM
