new engine?? - JeepForum.com
post #1 of 7 Old 03-16-2007, 12:31 PM Thread Starter
maddog89
new engine??
I have any 1994 Grand Cherokee with a I-6 4.0L engine. Does anybody know if I can install a newer or stronger engine without modifying other parts of the car???
maddog89 is offline
post #2 of 7 Old 03-16-2007, 12:40 PM
KrazyGimp
1982 CJ5
Pretty much any engine swap other than one that was stock will require some slight modding. The amount you need to do really depends on what you are going to swap in. We really need to know what kind of motor you are looking at to really give you an idea what you would be looking at in terms of other mods.
I can tell you right now that you would possibly be looking at new motor mounts, various wiring issues, driveshaft lengths and on and on. Also adapters might be necessary to mate your new engine to your existing tranny, but again this is dependent on the motor you choose. You can really open up a can of worms with this one. But on the flip side this site has lots of good info, just sue the search function and you should get a good idea of what will be needed to put "X" motor into "X" Jeep.
1982 CJ-5 Laredo 258, T-176, D-300
1972 240z in pieces...
Originally Posted by BESRK
...that's why you push in that little nipple (hehe.. I said nipple on the internet :D )
KrazyGimp is offline
post #3 of 7 Old 03-17-2007, 10:50 AM
heywaitfourme
stroke it, stock motor, lots more power! Love mine, search in this forum, my name, hoseclamp, bnovack, atomicmoose, vestjam, etc.......
2011 Grand Cherokee 4x4 black on black w/hemi
heywaitfourme is offline
post #4 of 7 Old 03-22-2007, 09:47 PM
Vestjam
I just put a 97 4.0 (after I rebuilt it) into my 95ZJ 4.0. It was a direct swap with the exception of the idle pully next to the a/c compressor (they were about 1/4" different in size, although I think I could have used either one) and the temp sensor on the thermastat housing.
The valve covers were different cast aluminum vs stamped steel (no drama there).
The 93-97 4.0 blocks (maybe others) are almost identical as far as bolt on points. The accessories change, on some, but if you stay close in years, it should be pretty straight forward.
Just remember.... if you change motor years, make sure when you need parts that you choose the right year for the part. (ie, 95 valve cover gasket is different that a 97 valve gasket... as is a temp sensor on a 95 vs 97.
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
post #5 of 7 Old 03-23-2007, 10:54 AM
tjstroker
I just bought an engine from Golen Engines and replaced my stock I6 4.0 in a TJ with a 4.6 Stroker (260hp 295+ft/lbs torque) . That sucker humps!
It's a direct bolt-on and is built to be a daily driver with lots of attitude. They build to run standard stuff like Autolite 985 plugs ($1.50 each) and same computer and everything. You can gain performance by adding larger thottle body, intake, etc but you WILL notice a significant change with it and all your existing equipment. They provide awesome technical support and are very friendly too.
Give Chad a call and he'll tell you about it. Tell him Jim from KY said hello!
tjstroker is offline
post #6 of 7 Old 03-23-2007, 07:55 PM
Vestjam
OK.... Dish.. How much $$$$$$$$ was the motor. Just curious.
Vestjam is offline
post #7 of 7 Old 03-27-2007, 08:33 AM
tjstroker
NOT CHEAP!
$3.5k
2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine 1SickWS6 Engines & Drivetrain 17 11-29-2016 07:24 PM
97wrangler Automatic and 4 cylinder engine. THINKING ABOUT AN ENGINE SWAP AND MANUAL BoatsJeep Engines & Drivetrain 0 11-12-2009 07:01 PM
Anyone use an engine lift plate with a leveler to pull an engine? tankcj Engines & Drivetrain 2 08-06-2008 02:29 PM
Engine differences between 89, and say 96 Engine Techies PLEASE step in JolshkerLS1 Engines & Drivetrain 4 02-27-2003 10:29 PM
replace 4cyl engine with 6cyl engine eastwood Engines & Drivetrain 5 01-23-2003 08:19 PM
