new engine? - JeepForum.com
post #1 of 8 Old 07-14-2013, 04:03 PM Thread Starter
mjdh_80
new engine?
Hey guys,
My 4.0 has been getting pretty tired. I found a nice 4.0 xj at a, you pull, yard around here. Don't know how many miles it has since it has a digital odo but everything is beyond clean. Doesn't seem to have any leaks from anything under the hood or drivetrain. No rust anywhere on the jeep. It was rolled so thats why it was scrapped.
I have a 98 TJ 4.0 5 speed. The donor vehicle is a 96 XJ 4.0 auto.
Does anyone know if there would be any problems swapping the engine out?
98 TJ, 4.0l, 2"Budget Boost, 31" Mud Country's, soft top
06 WK, 4.7l, Stock for now
mjdh_80 is offline
post #2 of 8 Old 07-14-2013, 08:28 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
XJ Cherokee and ZJ Grand Cherokee 4.0L engine blocks interchange.
2000+ TJ Wrangler and WJ Grand Cherokee 4.0L engine blocks interchange.
XJ/ZJ blocks and 2000+ TJ/WJ blocks do not interchange without significant modifications. (1991 to 1995 YJ and 1997-1999 4.0L TJ Wrangler blocks will interchange in XJ/ZJ and visa-versa).
TJ/WJ 4.0L Engine blocks underwent clean sheet design changes effective in the 1999 WJ Grand and 2000 TJ Wrangler. These blocks are not interchangeable with XJ/ZJ engine blocks. The reason is motor mount bolt holes and belt driven accessory mounting bolt holes are in different locations, or not present at all, TJ/WJ vs. XJ/ZJ.
XJ: "Regular" (not Grand) Cherokees 84-01
ZJ: Grand Cherokee 93-98 (Gen1)
WJ: Grand Cherokee 99-04 (Gen2)
YJ: Wrangler 87-95 (Gen1)
TJ: Wrangler 97-06 (Gen2)
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 8 Old 07-14-2013, 08:53 PM Thread Starter
mjdh_80
Whew thats a lot of great information. Thank you!
I'm pretty sure I'm reading it right in that my 98 TJ is interchangable with all XJs. Again thank you very much!
mjdh_80 is offline
post #4 of 8 Old 08-15-2013, 05:12 PM Thread Starter
mjdh_80
Ok I have another question. Since my engine is getting tired I might look into replacing the whole dtivetrain. My tj is currently a 5sp but my wife doesn't know how to drive a manual. What is the best engine/transmission/transfercase I can drop in it?
This will still be my D.D. So nothing crazy.
I was thinking to stay with a 4.0 still but grab a whole drivetrain out of a wrecked jeep with an auto and I'm sure I would have to get the ecu also and didn't know if I would need a different transfercase too. I am wondering what years are best. I am however also open to suggestions of other manufacturers. But I don't have resources to do the axles yet.
mjdh_80 is offline
post #5 of 8 Old 08-15-2013, 05:21 PM
Tailwheel42
As far as the transmission: 3-speed TorqueFlite 32RH automatic. Yes, it does NOT have overdrive, but I'd take one any day over my 42RLE auto. If I could do it over I would of purchased an older TJ with the 32RH and saved a lot of money!
Tailwheel42 is offline
post #6 of 8 Old 08-16-2013, 12:08 AM
Idahotrout
Sounds interesting, good luck
Idahotrout is offline
post #7 of 8 Old 08-29-2013, 01:27 PM Thread Starter
mjdh_80
Ok so my cousin is thinking about putting a 5.3 sbc in his little nissan. I know a lot of guys have put 350's in wranglers. But I'm wondering if I could grab a 5.3, all the wiring, and trans out of a wrecked truck and drop it in the tj? Really have no idea whats involved in "repowering". I've completely rebuilt engines before nut never put an engine from a different vehicle in something.
mjdh_80 is offline
post #8 of 8 Old 08-29-2013, 09:22 PM
uberxj92
1992 XJ Cherokee
There's Fab work for motor Tranny mounts. Wiring, several hours there. Linkage fabrication. Customizing drive shafts.
It's fun. I have put couple of diesels in xjs and mjs. Even put a LT1 in an xj. That sucked. Lol the guy drove it into a tree.
Anything can be done with the correct amount of blood sweat tears and cash.
IMO I would stroke a 4.0 and put her in there. I have 2 & am never looking back
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
