Needing new engine - JeepForum.com
post #1 of 4 Old 03-30-2010, 02:08 AM Thread Starter
familyofjeeps
Needing new engine
Well....... this bums me out.... in Dec of 08 when I returned home from all my training for the Army Reserves I purchased a 2001 Jeep Cherokee XJ (with 100k had an evap leak, so i picked the jeep up for $5k) so i could roll with my dad and my uncle (who both have XJs) and i put a 3.5"lift (shackle rear w/ add-a-leaf) 31x10.5s A/Ts, Grille Guard, Rear bumper with Swing away tire carrier, and roof rack......... well it now has just turned over 143k and i have a loud Ticking noise, after an hour with my mechanic i found out indeed it is a ROD..... and what realy "erks" me is that there are no local mechanics that are willing to put new rods in it....... so i decided to put a new engine in it...... My uncle picked up an engine for 2300 and had an 5yr/100k warranty but has no clue what website he purchased it from..... SO WHAT IM ASKING is if anyone knows of a website that has better than stock 4.Os for 2300?????? or around that price range.......
Thanks Bummed Yell'r XJ
familyofjeeps is offline
post #2 of 4 Old 03-30-2010, 03:31 AM
Rickyb
Why not just put in one that has a good warranty?
5yr 100k is pretty good warranty for a $2300 engine.
Rickyb is offline
post #3 of 4 Old 03-30-2010, 03:33 AM
Rickyb
Rickyb is offline
post #4 of 4 Old 03-30-2010, 08:30 AM
Happy Joe
So ask around the local hot rod/4WD community and find someone willing to fix it.
Are you certain its not a lifter?
A bad rod won't just tick it will sound like a hammer. I would say pull the bottom end apart, check the rod bearings and main bearings, along with the crank.
The only reason that the rod, itself, would be bad would be if you somehow spun a bearing or maybe hydro-locked it and bent the rod. If the crank is still good, (it should be if it really only ticks, as opposed to thumps or bangs) you might be able to get away with replacing the bearings, gaskets and seals (a Saturday project).
It sounds like you need a better mechanic... Rod and main bearings are not a terribly big deal, even if the crank needs replacing/regrinding.
Enjoy!
'06 TJ Rubicon; seemed like a good idea at the time; had many CJs...
Happy Joe is offline
engine , problems , purchasing , rod , trouble
noob needing some help... mrtosh Engines & Drivetrain 16 08-29-2012 02:46 PM
Welding rookie needing help brodon Fabrication Shop 10 03-25-2010 07:58 PM
needing roof racks jaygenesky General Jeep & Off-Road Equipment 2 09-24-2009 05:00 PM
Needing DOM, Please help. Airborne4X4 Fabrication Shop 5 06-15-2007 10:58 AM
needing professional advice JKNIPE2000 Audio, CB & Ham Radios, GPS, & Electrical 17 04-30-2004 07:52 AM
