Need to replace a cracked cylinder head... - JeepForum.com
post #1 of 2 Old 05-18-2011, 03:10 PM Thread Starter
balentinebj
1999 Wrangler 2.5l 4cyl (118k miles)
I need to replace a cylinder head that is cracked. I was told by the shop that it appears that someone welded a crack (before I had the Jeep) and the weld has apparently failed. I have a warranty, but they are not going to cover it because of the weld. I have a friend that is a mechanic and we're going to do this ourselves. I have a pretty goo idea of what I need, but I would appreciate it greatly if someone would let me know what is needed to pull this off so I don't miss something. (I'm talking about parts, besides the head itself).
thanks
balentinebj is offline
post #2 of 2 Old 05-18-2011, 04:23 PM
JeepFreak1982
New head, new head gasket, new intake manifold gasket, new head bolts, new thermostat and housing gasket, new valve cover gasket, good torque wrench, antifreeze and oil, that should cover it
JeepFreak1982 is offline
replaceing head. Should i replace head bolts? vosevichs Engines & Drivetrain 7 03-16-2011 01:11 PM
Cracked 4.0 head. Where to get replacement.? PeteJeepR Engines & Drivetrain 0 02-13-2011 06:57 AM
Cracked exhaust manifold.. Weld or replace logans97jeep Engines & Drivetrain 3 06-24-2009 12:59 AM
2000 4.0L cracked cylinder head sgaenzler Engines & Drivetrain 3 10-24-2006 05:41 AM
Cracked 4.0L Head RockPaws Engines & Drivetrain 5 06-20-2005 04:20 PM
