Need help (water in oil) - JeepForum.com
post #1 of 5 Old 03-18-2014, 09:27 AM Thread Starter
bbman82
Ok searched and searched through the threads and found nothing. So heres my dillemma
Out playing in my 08 jk, i just put 4in lift and 33x1350 toyo mt on it.. mud was deeper than i thought and stuck it.. when i got it out, aftermarket air filter was trashed and had water in oil.... now, it ran for about 10 minutes (before i knew there was water in oil) then shut off....had to be towed home.....
Changed oil and filter 4 times, now i have straight oil, no water, pulled plugs overnight and cleaned them up replaced air filter. But now, when i crank it and it runs, it sounds like a diesel and every so often it will have this squeaky knocking sound and the oil pressure light is on..... dont want to drive it but need to figure out whats wrong with it.....its my DD and the wife is Pissed!! Lol
PLEASE HELP
bbman82 is offline
post #2 of 5 Old 03-18-2014, 06:11 PM
carnuck
1984 J-Series Truck
Take off the oilpan and make sure you didn't toast your rod bearings.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #3 of 5 Old 03-18-2014, 06:37 PM
BlueRubiconrich
that sucks, you can't compress water, it will bend valves.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #4 of 5 Old 03-19-2014, 10:00 AM
Hungus
Bend a valve, not so much. Bend a connecting rod or bust a piston, most certainly...
2005 LJ Rubicon Sahara Edition #867
Hungus is offline
post #5 of 5 Old 03-19-2014, 10:15 AM Thread Starter
bbman82
So im takin it..... nothin easy to fix.... daggummit! That sucks
bbman82 is offline
