Need Help!!!! Jeep Hesitation - JeepForum.com
post #1 of 4 Old 10-25-2013, 06:34 PM Thread Starter
sdrasal
Let see if I can explain this!!!!!
I have a 1995 Jeep Cherokee Sport Country 4.0L.
The jeep has a hesitation when accelerating from a stop. No matter hot or cold or time of day. The engine rpm's will decline before the vehicle takes off. Also, when the vehicle is in park or neutral I will step on the gas pedal to build rpm's, the engine will hesitate before gaining the rpm's, when the rpm's decline back to normal the engine acts like its going to die before catching itself and stays running. (A couple of times it has died) I hope this makes sense!!!!!!!
This is what I have done soooo far to fix.....
Cleaned throttle body
New TPS
New Idle Air Control Valve
New Fuel Filter
New O2 Sensors
New plugs and wires
After replacing the above I have noticed a difference in the hesitation when taking off from a stop, but the jeep stills acts up in park and in netural.
My next action plan in to take the fuel rail off and test and replace the injectors, but if someone has been in the same boat and can steer me in the right direction. Thanks you in advance,
Steven
sdrasal is offline
post #2 of 4 Old 10-25-2013, 06:45 PM Thread Starter
sdrasal
No Check Engine Light
Forgot to mention
no check engine light
sdrasal is offline
post #3 of 4 Old 10-26-2013, 01:37 AM
uberxj92
1992 XJ Cherokee
What's your fuel pressure?
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #4 of 4 Old 10-26-2013, 08:48 AM Thread Starter
sdrasal
I haven't check that yet, I'll do that and re-post. Thanks for the reply....
sdrasal is offline
