Quantcast need help with ford 9in pinion!!!!! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > need help with ford 9in pinion!!!!!
Old 05-10-2008, 02:19 AM   #1
Jenyus425
1992 XJ Cherokee
I went to change my pinion seal and took out my bearings to check them out and when i went to put them back in, the pinion was moved all the way to the right and now i cant get the bearings back on. i hav the back axle jacked up with the tires off the ground and tried moving the tires back and forth and the pinion just moves up and down a little bit. here are some pictures:
also, before i changed the seal, when i would accelerate the whole car would slam, for lack of a better word. When i removed the pinion seal, i noticed a lot of play in the pinion. What would cause that?
I have a ford 9in with a detroit locker.
92 XJ
6.5in Rusty's longarm, welded 32 bolt beadlocks, high pinion shaved and detroit locked 35 spline ford 9 from Currie, rear disc brake conversion, D30 w/ TrueTrac, 37"x12.5"x15 Goodyear Wrangler MTR, SYE, 3/8" steel bumpers, rocksliders, 1085 excessive watts of light in the front.
Jenyus425 is offline   Reply With Quote
Glock Forum
