need help buying a 350 - JeepForum.com
post #1 of 5 Old 06-02-2011, 12:55 AM Thread Starter
95yj-af
I found a chevy 350 smallblock at the recycling center today. The guy working the yard said i could take it for $150. I need help to determine if it is an actual 350 or a 305. It is in a 1988 Chevy van, the tag under the hood says 5.7L, but I'm unsure about determining if it was still that. Are there any easy ways to determine that. I also need to know if $150 is a good deal. I have to pull the engine myself but that will be no problem.
To recap
Is $150 good deal for a running 350?
What is the easiest way to determine if it is really a 350?
95yj-af is offline
post #2 of 5 Old 06-02-2011, 03:56 PM
baldfatdad
1984 CJ8
I would say put this question on a Chevy forum. Also ask about the heads. There a a bunch of different heads.
Can you swap it for another engine if you find its no good?
I'd do a compression check before I pulled it. And/or pull the heads to check the cylinders to see if its been bored. Check the taper and round too. Pull the pan and check the crank.
baldfatdad is offline
post #3 of 5 Old 06-05-2011, 01:01 PM
cubfanbudman
On the top of the block behind the head on the driverside there should be cast numbers either 50 or 57. I think that's for 87 up only.
1995 YJ -TBI350/NV3500/231J RC 2.5
1996 ZJ Laredo-4.0 NP242
1996-ZJ-Orvis Edition
Doug
cubfanbudman is offline
post #4 of 5 Old 06-05-2011, 01:12 PM
LiftThis
Starting in 86 GM started casting the engine size of the block next to the casting number on the drivers side rear on top of the bellhousing flange.
14088548, 14093638, 14101148 should be for a 350
14088551, 14093627, 14102058 would be 305s
-2000 TJ
-2001 XJ
LiftThis is offline
post #5 of 5 Old 06-25-2011, 11:06 AM
linedog3
get the casting numbers off the back left of the block and then match it on this site http://www.thedirtforum.com/castings.htm
linedog3 is offline
350 , help needed
buying an amp bobcatfanman14 Audio, CB & Ham Radios, GPS, & Electrical 9 04-04-2009 07:54 PM
help buying a winch india General Jeep & Off-Road Equipment 5 10-25-2008 07:21 AM
Need Help Buying Dana 44 TJ_Shane Engines & Drivetrain 1 07-31-2008 10:05 PM
Buying an engine for a CJ-7 Raccroc Engines & Drivetrain 1 05-03-2008 11:03 PM
Buying my first GPS need help newvances Audio, CB & Ham Radios, GPS, & Electrical 19 12-29-2004 01:35 AM
