Need Help Badly - JeepForum.com
post #1 of 2 Old 08-05-2002, 06:01 PM Thread Starter
CJ7Jeff
Need Help Badly
Okay, I have changed the thermostat , the fan clutch, and flushed the system. I even went as far as to borrow a buddy's electric fan setup to see if that would help. Why does my Jeep continue to run hot only on the highway? I am stumped. Please help! Any and all comments would be appreciated.
'85 CJ7 258 w/Weber Carb and Nutter Bypass. Dana 44's F&R, 3.73 gears with Trac-Loc rear. Always looking for peoples $0.02.
CJ7Jeff is offline
post #2 of 2 Old 08-05-2002, 08:09 PM
johny1i
johny1i's Avatar
Considering the age of your jeep, and if it hasn't been flushed on a regular basis, you may need to have the radiator rodded to remove the calcium build-up. The best thing to run in a radiator is antifreeze and distilled water, but we all get lazy and put tap water in them. The build-up will seriously obstruct the flow of water. Sometimes the cost of rodding one is so close to just buying a new one that it isn't worth it. Therefore, ask for a price first and compare it with the cost of a new radiator.
Also, you may check your lower radiator hose to make sure it has a spring inside of it. Without one, the hose can collapse due to the suction when the engine is running at high rpms (high flow).
These are the two simplest suggestions I can make. Timing that is set too low (not enough advance) makes the engine run hotter, but we're probably splitting hairs at that point. You can keep that in mind, though, if these first two suggestions are null.
Currently an '86 CJ-7 and a '77 CJ-7 Golden Eagle---#4 and 5 following a '01 Sahara, '90 Sahara, and '85 CJ-7....
johny1i is offline
Tru-Trac front pulls badly letsroll Engines & Drivetrain 5 02-17-2010 01:47 PM
something is clicking/ clunking badly in 4wd only! thelazerviking Engines & Drivetrain 4 01-04-2008 12:35 PM
