In need of help - JeepForum.com
post #1 of 6 Old 09-23-2017, 02:22 PM Thread Starter
penner1960
1974 CJ5
In need of help
I just recently purchased a 1974 Jeep CJ 5, About a half hour ago I was sitting in it thinking of heading to Big Bear lake and wanted to test the 4X4 for operation, it went into 4 wheel low no problem smooth, with hubs locked I moved up and down driveway everything seemed fine I stoped got out unlocked the hubs placed 4 speed shifter in neutral but when I tried to move the transfer shift lever back to 2H I can't get it to move, am I hosed or is this FNG doing something wrong I tried with clutch engaged and engine running , and with engine off clutch in and out I can't get it to budge, I hope I have not purchased a lemon my wife already has eyes on me for spending the money on a toy in the first place anyone have any ideas?
penner1960 is offline
post #2 of 6 Old 09-23-2017, 05:05 PM
mukluk
It usually helps to be moving at least a couple miles per hour when shifting the transfer case.
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #3 of 6 Old 09-24-2017, 09:31 AM Thread Starter
penner1960
1974 CJ5
Problem is solved I Moved the jeep forward and back a couple of times and the shift lever moved freely, all is well in Newport Beach, Thank You
post #4 of 6 Old 09-24-2017, 09:50 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Any time you run the 4X4 on dry hard surfaces, you will get what is called"wind up". The happens because there isn't a diff in the t case to compensate for the different rotations speed between the front and rear axle.
Soooo......First:
Don't run the rig with the hubs locked and the t case engaged on the pavement. You can run one or the other but not both at the same time.
If you do and can't get the t case disengaged:
1 unlock the hubs. They are spring loaded and if working properly, will disengage themselves when the driveline pressure is relieved.
2 Keep the rig moving while pushing on the t case lever.
3 Try getting a tire in the gravel (while moving and pushing on the t case lever).
Long periods of driving while engaged can damage the drivetrain.
bazinga
jeepdaddy2000 is online now
post #5 of 6 Old 09-26-2017, 12:02 PM Thread Starter
penner1960
1974 CJ5
Rgr that and thank you for the heads up , obviously I have a lot to learn I am just glad I did not do permanent damage to my baby, thank you
post #6 of 6 Old 09-28-2017, 10:43 PM
jeepdaddy2000
1971 CJ5
Very nice......
bazinga
