NEED help! 4.0 major sputter and power loss - JeepForum.com
post #1 of 6 Old 08-14-2011, 09:58 PM Thread Starter
creepyjeep420
ok i have a 98 tj 4.0... ran great forever then i got a hole in my gas tank and it caught on fire. no wires got burned. i checked the compression all cyl are about 130 psi. ( not exactly how to check it right but i got a guage and tured the motor over a couple turned and it would hit 90 then 125-130) took the fuel line off the rail and its pumping plenty of gas. checked all the injectors and there all getting fuel. spark pulgs all all pretty new and all fireing. so im lost.... it runs great at about 1/2 throttle but wide open it sputters likes crazy. when i turn hard or get it leaning hard four wheeling it will barley run. fuel lines are clear. i got a gas tank out of a 4cyl and had a hard time getting the plastic locking ring on but i got it tight. ive had alotr of electrical problems. (brake lights, turn signals, horn, all kinds of electronics) the previous owner put a radio system in and wired all kinds of stuff together. i have put a new exhast valve, head gasket, alternator, plugs, wires, distributor cap and rotor button. seems likes it sucking air somewhere but it dosent leak gas. i at missing my jeep and four wheeling really bad. if anyone has any ideas on how to get it running good again i would really REALLY appriciate it. i do all my work on my jeep and hate takeing to a shop and letting some one mess with it. i miss wheeling so bad and its summer so come on guys give me some advise ANYTHING HELP thanks
seems like its sucking air and not getting enougth fuel
creepyjeep420 is offline
post #2 of 6 Old 08-14-2011, 11:56 PM Thread Starter
creepyjeep420
really could use some advise. just took it out and it pretty much dies when i go around a turn. anyone know if it is ok to use a 6cyl sending unit in a 4cly gast tank? ik jeeps cut out when you turn and your low on gas but i know it has at least 5 gal in it right now..... could really use some help im desperate. gunna get a fuel pressure tester and try that.
post #3 of 6 Old 08-15-2011, 02:54 AM
N3KRV
i'm just guessing here but maybe the fire did some damage to the fuel pump and filter?
N3KRV is offline
post #4 of 6 Old 08-15-2011, 02:18 PM Thread Starter
creepyjeep420
i dont think so the sending unit was down in the tank and i fire was pretty small and i put it out pretty quick. some people have been saying the cat maby be clogged any one have any advise on that?
post #5 of 6 Old 08-15-2011, 02:22 PM
mightydog78
spark plugs, o2 sensor (upstream), clogged catalytic converter...
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
post #6 of 6 Old 08-17-2011, 07:30 PM Thread Starter
creepyjeep420
plugs, wires, dis cap, and rotor button are less than 6 mo old. compression is perfect all are about the same 125-130. anyone know how i can clean the sending unit and filter?
4.0 , power loss , sputtering
98 tj 4.0 major power loss creepyjeep420 Engines & Drivetrain 1 04-19-2012 10:50 PM
04' Rubicon Loss of Power Major Misfire Tmsnake1 Engines & Drivetrain 1 03-14-2011 01:22 AM
What causes power loss? dogbluedrummer Tires & Wheels 4 12-12-2007 02:53 PM
More Power Loss Squandith Audio, CB & Ham Radios, GPS, & Electrical 2 12-07-2005 02:08 PM
Power loss SpikeSpeigel Engines & Drivetrain 3 09-06-2003 11:16 AM
