Need help! 2000 wrangler (TJ) sport A/C - JeepForum.com
post #1 of 12 Old 04-02-2013, 10:03 AM Thread Starter
doitnthemud
I'm pretty new to all of this and I'm trying to work on my jeep myself...my clutch pulley has gone bad. I have no idea where to begin trying to replace it. Any help or advice is greatly appreciated! Thanks in advance!
doitnthemud is offline
post #2 of 12 Old 04-02-2013, 06:20 PM
GilaMtnJeep
GilaMtnJeep's Avatar
What is "bad" about it? Pulley grooves worn or clutch not engaging? If it's not engaging is there enough freon in the system? If it is low there is a pressure switch that will not let the clutch engage.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 12 Old 04-03-2013, 01:02 PM Thread Starter
doitnthemud
I mean it ain't doing anything. At all. I'll check the freon level...but I was told I needed to replace the clutch?
post #4 of 12 Old 04-03-2013, 01:39 PM
GilaMtnJeep
Did an AC shop/tech tell you that the clutch was bad?
If you want to do a quick check before you spend $$ find the pressure switch. It should be in one of the AC lines on the pass side if the engine. Remove the electrical connector, start the Jeep and turn the AC on, and put a jumper in the connector. If the clutch pulls in your low on freon. If it doesn't, make sure there is 12V at the clutch connector with the jumper in place. If there is then the clutch is bad. They can be a PITA to remove.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
post #5 of 12 Old 04-03-2013, 03:23 PM Thread Starter
doitnthemud
My uncle looked at it. He's a mechanic. Ok I will try that out as soon as I get off work...and yea, it's looking like it's going to be a pain if I end up needing to replace it.
post #6 of 12 Old 04-03-2013, 04:05 PM
GilaMtnJeep
Ok, my apologies. Chances are he's got you covered.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
post #7 of 12 Old 04-03-2013, 08:35 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Here is what I did to fix my '01 WJ AC clutch.
http://www.jeepforum.com/forum/f310/...ement-1097048/
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #8 of 12 Old 04-04-2013, 07:49 AM Thread Starter
doitnthemud
No need to apologize. I'm trying to get this figured out (uncles a busy guy and he took a quick look over easter) and I really appreciate your help! it's hard to find people that know what they are talking about that has the time to spend workin on my jeep for free. Haha!
post #9 of 12 Old 04-04-2013, 08:03 AM Thread Starter
doitnthemud
Thanks!! This looks like its gonna be fun!!! Lol
post #10 of 12 Old 04-04-2013, 11:44 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
You might have more room up front since you are dealing with a TJ and not a '01 WJ
post #11 of 12 Old 04-04-2013, 12:03 PM Thread Starter
doitnthemud
Maybe? Think I can get to it without removing anything? Or will the power steering need to be taken out?
post #12 of 12 Old 04-04-2013, 01:48 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Attachment 600620
Attachment 600622
I'd remove the serpentine belt and unbolt and slide the PS pump out of the way. The more room the merrier!
