need help - JeepForum.com
post #1 of 5 Old 04-16-2012, 07:14 AM Thread Starter
Dmartinez
need help
My 96 jc won't start. My husband replaced the distributor cap, the crank shaft sensor, fuel pump, fuel lines and are stumped. There is no power to the battery wiring in the fuse box. Does anyone have knowledge on what can get my Jeep going? Please help!
Dmartinez is offline
post #2 of 5 Old 04-16-2012, 09:23 PM
Samcro
Was there power at the fuse block before he changed all of that stuff?
Samcro is offline
post #3 of 5 Old 04-17-2012, 05:04 AM
jr4x4
check for spark at coil. & mtry wiggling connections at your pcm while someone tries to start it.(maybe bad connection.
jr4x4 is offline
post #4 of 5 Old 04-17-2012, 08:42 AM
1995wrangler
Try to wiggle the crankshaft pos senser while trying to start it. If the pcm doesnt get signal in one sec it shuts the asd relay down. Is it a factory senser? I just went throug three before i found one strong enough to pick up a wrench of my toolbox.
1995wrangler is offline
post #5 of 5 Old 04-17-2012, 08:45 AM
1995wrangler
Also unplug the crank senser, with the key one, check for five volts, then you know the pcm is asking for signal?
