Need engine specs for 2.5L and the old I6es - JeepForum.com
post #1 of 4 Old 01-29-2006, 05:07 PM Thread Starter
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
Well, I've found an old Opel Ascona I'm about to have some fun in, and figured, since I can get a good deal on a 2.5L (free), why not put that into it? Well, I need to know the measurements of the engine to find out if it will fit into the engine compartment. Since the Ascona is such a light car, the 2.5L should do fine in it, and when I get ahold of it, its not going inside it in stock form anyway. So, what's the height length and width of the engine, and all necessary accessories? What about the I6es? Power steering, AC, and power brakes dont exactly have to be included. Also, the old CJ 3,4, and 5 speed transmissions, what're the measurements on them? I need to fit them into a smallish transmission tunnel in this thing. Sorry guys, I tried to measure it myself, but all I have is an AX5 and 2.5L, and I dont think my numbers on the 2.5L were too accurate. I figured some of you would know though.
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #2 of 4 Old 02-05-2006, 02:48 PM Thread Starter
CoriolisSTORM
WHAT?!
2010 JK Wrangler
Come on guys, I know some of you all know where I can find the specs. All I need is the length width and heighth of the I6es and 2.5L, I know some of you probably know. A 252 or 4.0L would be pretty sweet in a car that came from the factory with a 1.9L
post #3 of 4 Old 02-05-2006, 05:20 PM
bobjp
I measured my 4.0 at about 32" X 24" X 25." It was a rough measurement and that included the accessories and manifolds. I don't know about the 2.5L.
I don't think your problem is going to be with getting it to fit, it is going to be making everything work. If you go with anything other than a 4 cylender you're going to have to beef up the suspension. Plus if you want a computer controlled engine you will have to figure out the crankshaft position sensor. It'd probably be best to swap out the whole engine and transmission as one unless you know someone who can make an adapter for you.
For any parts you may need, you could try advance adapters. But I don't know if they have stuff for opels.
bobjp is online now
post #4 of 4 Old 02-05-2006, 07:44 PM Thread Starter
CoriolisSTORM
WHAT?!
2010 JK Wrangler
I know, that's why I plan on using an older transmission from a jeep if I can get it to fit in the transmission tunnel. I might also do an AWD set up as well with it by using an NP 229 or 242 if the driveshaft isn't too short afterwards. The problem with the Opel is the old engine was light and these are heavier, and the body is of course a unibody. Thank you a ton for your effort!
AMC engine specs? Mud4U Engines & Drivetrain 2 10-19-2006 09:30 PM
engine specs redrum007 Engines & Drivetrain 3 09-03-2006 11:37 PM
1998 Engine Torque Specs I-6 / RearMain MudFlapper Engines & Drivetrain 2 05-31-2004 01:46 PM
4.0 I6 specs? evilpsych Engines & Drivetrain 1 02-11-2002 03:10 PM
4.0 I6 specs? evilpsych Engines & Drivetrain 1 02-10-2002 08:51 PM
