need a battery tip.please. - JeepForum.com
post #1 of 3 Old 03-16-2013, 09:12 PM Thread Starter
hildahl
My 1988 jeep XJ's batterie keeps dying. The batterie is good and the alternator is good. Im thinking maybe a short or something. Doesn't happen all the time just once in a while. Any ideas where to look?
hildahl is offline
post #2 of 3 Old 03-17-2013, 08:49 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
first thing to check is current draw with key off.. lift the posi lug, measure with a meter to see if there is any current being drawn from your battery to your frame ground.. if so, pull one fuse at a time to see which circuit is shorted or still on.. if your battery is known to be good, then something is staying on drawing from the battery..
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #3 of 3 Old 03-19-2013, 10:22 PM
jokerchief462
Look at your cables and see if there isn't corrosion on them inside the insulation or the plastic coating. If there is any sign it will cause high resistance and can cause starting problems. Battery and tray should also be cleaned with a brush and clean water.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
