I Need Info on push rod length for a 304 AMC.
New re built
Flat top pistons,
Comp cams Hi Energy 268 Cam
Hydraulic lifters
AMC rockers
When I assembled my engine I measured the lifter compression after the rockers were torqued. The averaged .110 with some being .120 of travel left in the lifter.
I consulted my engine builder and he said that was OK.
During the build I spun the oil pump on the stand and watched the lifters pump up and oil out the top of each rocker.
So I am certian all the lifters are pumping up.
I also pulled the valve covers after 500 miles all looked good.
To the point I have some valve train tap sounds like a solid lifter engine.
How much lifter compression would be safe.
I would like to change the push rods to make the tick go away, but don't know how much free travel hydraulic lifters would be happy with.
Of course I will remove a Rod or two and Check the OAL before ordering
Or it may be normal to hear them through the fire wall.
