"Nano" Lubricants - JeepForum.com
post #1 of 12 Old 03-23-2012, 12:38 PM Thread Starter
Flashback
"Nano" Lubricants
Has anyone tried any of the new "nano lubricant" additives ?
The marketing sounds very interesting but I can't seem to find any feedback from folks who have actually been using them for a while.
Any feedback, pros or cons ?
What about longevity ?
Flashback is offline
post #2 of 12 Old 03-23-2012, 01:05 PM
Millermagic
Additives are generally seen as snake oil ...
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #3 of 12 Old 03-23-2012, 02:30 PM
Ross00TJ
There is no reason anything should need additives that aren't already in whatever you are using. Unless you are a tribologist and have the equipment to measure what effect adding said additive will have on the oil you are using and what the final mixture will produce you are likely doing more harm then good and may be canceling out other needed additives by adding something that isn't needed.
Stay far away from additives.
Future Electrical and Computer Engineer - University of Colorado - Boulder | Bringing Logic to JeepForum since 2010!
"Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Ross00TJ is offline
post #4 of 12 Old 04-06-2012, 01:42 PM Thread Starter
Flashback
In the time of the great explorers Columbus, Magellan, and Drake many areas of the earth's surface, especially the oceans, were uncharted. Most of the people still believed that the earth was flat. Legend among seaman held that sea monsters and other creatures lived in these uncharted regions. As a result, the map makers of this era commonly place the words "beyond this point their be dragons" on uncharted areas.
post #5 of 12 Old 04-07-2012, 08:58 AM
Foundrydude
Columbus, go ahead and use whatever you want if you're that confident it works.
The thing with additives is the average home user doesn't have much in the way of real data to offer. Unless you're responsible for a fleet of identical vehicles and can compare the condition of internal engine components of two or more vehicles, some without additives and some with.......then it's entirely a guess.
IMO (based on disassembling engines) is that synthetic oil and a premium filter on a 3000 mile change interval will make the lubricated surfaces last far longer than the head gaskets or vehicle's body. Unless of course you're talking about a used vehicle that wasn't cared for initially, and may already have eroded surfaces that will shorten longevity no matter what type of lubricants are used.
Foundrydude is offline
post #6 of 12 Old 04-08-2012, 09:08 AM
wgirvine
1992 XJ Cherokee
Oil additives are carefully engineered to gently extract 20-dollar bills out of your wallet. Nothing more.
The road goes on forever, the party never ends....
wgirvine is offline
post #7 of 12 Old 04-08-2012, 10:48 AM
Pillswoj
Just the fact that they use the term "nano" means this is marketing hype. It seems as if everything is jumping on the nano bandwagon ever since the scientific breakthrough in "Carbon Fibre Nano Tubes" which have no application in lubrication.
Nano actually typically refers to a particle size, 1000 Nanometers = 1 micron
"Nano" in Marketing is the evoluation of "Micronized" in other word they have found a way to make the solid particles even smaller but how much smaller is the question. No one ever defined the size range for something to be "micronized" and no one is saying what the size range is to be Nano.
Fact of the matter is most additives that contain solids be they teflon, graphite or something else have been shown to have no benefit and potentially cause harm.
Friends don't let Friends run Bosch
Pillswoj is offline
post #8 of 12 Old 12-26-2013, 07:03 PM Thread Starter
Flashback
Any new comments ???
post #9 of 12 Old 12-26-2013, 07:10 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The 4.0L engine design is nearly as old as you are. Plain old dinosaur derived oil, changed with regularity, should make your 4.0L last about 300,000 miles.
CJ7-Tim is offline
post #10 of 12 Old 12-26-2013, 07:17 PM
jay-h
There is some really cool stuff being developed with nano technology, but NONE of it comes in a bottle at Pep Boys.
What we will see is exotic electronic components, hard surfaces with great wear or corrosion properties, powerful battery systems etc. But these will be new products designed from the ground up with nano tech, not added later.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #11 of 12 Old 12-26-2013, 08:03 PM
BIGBADWOLF
Unless you have a degree in chemical engineering leave well enough alone.
BIGBADWOLF is offline
post #12 of 12 Old 12-27-2013, 06:12 AM
jay-h
Originally Posted by CJ7-Tim View Post
The 4.0L engine design is nearly as old as you are..
Older than most people here. That engine design first appeared on the Rambler American back in 63
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
Keeping the front end "down"/hill climbs/Instant Center... RaggedOleMan Advanced Jeep Tech 118 07-06-2015 12:55 PM
