mystery engine? - JeepForum.com
post #1 of 11 Old 11-16-2012, 01:04 PM Thread Starter
77ChiefS
1977 FSJ Cherokee
Ok, so I have a 77/78 Chief. 360/th400. Since I've been driving it I've been trying to trace all of the odd sounds it has. One that I'm still having trouble with I's a rocker arm tick. I had one shop try to tell me it was a bad wrist pin...I have pulled the valve covers roughly 4 times and every single time I manage top find some of the rockers loose. The motor was rebuilt looking ago but still fresh, 60k. It has said studs but no bridges, tried to buy and install then and they don't fit...it has oblong locking nuts with no washers tisk are very hard to remove and tighten, but when I manage to, the rockers do go quiet. For about 5 minutes...I don't know too much about amc motors so I'm a little lost...also the motor feels stronger than 140hp and it revs to about 4600. I'd like to swap over to full rollers as well.
77ChiefS is offline
post #2 of 11 Old 11-16-2012, 03:53 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Sounds like it's an early 70s engine.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 11 Old 11-16-2012, 04:03 PM Thread Starter
77ChiefS
1977 FSJ Cherokee
How early though, I haven't looked at the heads where the pushrods come out but the pivots are round like a Chevy...
77ChiefS is offline
post #4 of 11 Old 11-16-2012, 04:56 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
See if this helps:
http://www.ifsja.org/forums/vb/showthread.php?t=160126
post #5 of 11 Old 11-16-2012, 05:00 PM Thread Starter
77ChiefS
1977 FSJ Cherokee
Cool thanks ill check it out when I get home.
77ChiefS is offline
post #6 of 11 Old 11-17-2012, 11:13 AM Thread Starter
77ChiefS
1977 FSJ Cherokee
Same casting number on the head, and it has the oblong ports for the push rods. So I should be able to just slap on some rollers rockers without issues right? I was going to throw some washers under the nuts and some lock tight on the threads till then. should be fine right?
77ChiefS is offline
post #7 of 11 Old 11-17-2012, 11:59 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by 77ChiefS View Post
Yup and casting number, and it has the long ports for the push rods. So I should be able to just slap on some rollers with how issues right? I was going to throw don't washed under the nuts and some lock tight till then. should be fine right?
What language is this?^^^
post #8 of 11 Old 11-17-2012, 12:02 PM Thread Starter
77ChiefS
1977 FSJ Cherokee
Haha, I believe it's stupid-smart-phone-and-lack-of-coffee-nese...
77ChiefS is offline
post #9 of 11 Old 11-17-2012, 05:31 PM Thread Starter
77ChiefS
1977 FSJ Cherokee
These are the rockers that came in my jeep.
77ChiefS is offline
post #10 of 11 Old 11-17-2012, 05:34 PM Thread Starter
77ChiefS
1977 FSJ Cherokee
And the same casting number.
77ChiefS is offline
post #11 of 11 Old 11-18-2012, 06:13 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Early motor then.
