Is this my Transmission??? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Is this my Transmission???
Travelling with Pets?Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!
Unread 06-19-2009, 06:05 PM   #1
sachase
I have had problems shifting into 3rd and 4th recently. If I double clutch it shifts fine but if not it grinds pretty bad. And no matter what I do if I'm downshifting to 4th or 3rd it grinds. I was hoping a transmission lube change would help with no avail. Slave and master seem to be fine. Clutch seems to be fine too (no slipping). I am assuming that the syncros have gone (150000 miles) Any expertise on the subject would be a great help.
_______
l l,[____],
l---L -0lllllll0
()_) ()_)---)_)
White 95 YJ 2.5L 18mpg, no lift, 30x9.5s, and a whole lot of fun.
sachase is offline   Reply With Quote
Unread 06-20-2009, 05:21 PM   #2
Mean Max
Don't poke the bear
Mean Max's Avatar
At a glance, it does present the symptoms of worn syncros.
However, air in the hydraulics can present the same symptoms. Check for a fluid loss in the master cylinder, then check above the clutch pedal under the dash for signs of leakage. The master will leak fluid into the inside of the Jeep.
Also look at the slave mounted on the bellhousing for signs of fluid leaking, this would indicate a bad slave cylinder.
If there are no leaks present anywhere, bleed the system repeatedly! Flushing out all the old fluid & possibly any air will greatly improve your clutch's engagement/disengagement ability.
If that doesn't help, you may have to face the possibility of bad syncros.
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 06-20-2009, 07:20 PM   #3
sachase
I have inspected the slave pretty good but not the master. I'll flush it tomorrow and see what happens. Its just DOT 4 Brake fluid right?
_______
l l,[____],
l---L -0lllllll0
()_) ()_)---)_)
Unread 06-20-2009, 07:38 PM   #4
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes, DOT 3 or 4 compatible fluid.
Look under the dash for this.
Max
Unread 06-23-2009, 12:48 PM   #5
sachase
took it to a transmission shop today (AAMCO) they said everything looked good except for the transmission. "something is definitely going on in there." Now I guess I'm looking at a cool grand to get it rebuilt. Any other alternatives?
_______
l l,[____],
l---L -0lllllll0
()_) ()_)---)_)
Unread 06-23-2009, 01:58 PM   #6
Mean Max
Don't poke the bear
Mean Max's Avatar
Yep, get a FSM (Factory Service Manual) and then buy a master rebuild kit (all new bearings, syncros, & seals) from an eBay seller named "transdeals4u" and rebuild it yourself.
I just did my AX-15 and the kit was $187.50 including shipping.
Max
Unread 06-24-2009, 09:02 AM   #7
backwoodsgoop
worn syncros
If you have your tranny rebuilt or do it yourself of course its a good idea to change out the the clutch and most importantly lube the splines of the imput shaft (the clutch kit should come with a small packet of grease) this is one of the main reasons of premature synco wear.
The clutch has to slide on the imput shaft to release compleatly if it cant slide it drags and the syncros get over worked
backwoodsgoop is offline   Reply With Quote
Unread 06-25-2009, 08:57 AM   #8
sachase
I think rebuilding my transmission is a little over my head. I think I'm going to have to bit the bullet and pay to have it done. I will ask about greasing the spline. My clutch, master, and slave are not that old is it imperative that I replace them as well as the throw out bearing?
_______
l l,[____],
l---L -0lllllll0
()_) ()_)---)_)
Unread 06-25-2009, 01:24 PM   #9
jaywiz1977
Max
Man Max, you've got a pics of anything that could possibly go wrong in a jeep!Do you work in a shop and keep the camera ready at all times or just that unlucky?sorry to hijack BTW.
my build
There are alot of different people in the world out of all of them,it's the normal ones that scare me the most!
jaywiz1977 is offline   Reply With Quote
Unread 06-25-2009, 03:53 PM   #10
Mean Max
Don't poke the bear
Mean Max's Avatar
I do try to cover as many typical issues as possible with some photos, "a picture is worth a thousand words" they say! I have my camera with me on all my jobs, and in fact I have some rear main seal replacement pics that I need to upload that I haven't gotten to yet.
No I don't work in a shop, but I used to be a mechanic for Volvo/BMW/Mercedes-Benz dealers back in the day, so I try to do as much of my own work on our 3 Jeeps (2 YJ's & a WJ) and for other Jeep owners I know. I'm in the jet engine manufacturing business these days producing F-22 & F-35 Fifth Generation Fighter aircraft engines.
Max
Unread 07-01-2009, 03:33 PM   #11
sachase
Max
I bought the kit from Transdeals4u, $137.50 shipped. I am still researching if I want to try to do it myself. I also ordered a new clutch and throw out bearing. I figure the slave and master can wait for now.
_______
l l,[____],
l---L -0lllllll0
()_) ()_)---)_)
