My splines are "whooped" - JeepForum.com
post #1 of 8 Old 09-13-2013, 07:13 PM Thread Starter
Lincolnwelding
I recently got my sye and driveshaft put in and was told my splines are pretty whopped. I want to start builing up my rear axle a little and want to start with my splines. My question is will this part fix it?
http://m.quadratec.com/products/prod...=26125+0103+07
"Piper, theres a big difference between wingin it, and seeing what happens"
Want to change my forum name to jeep wheelikers
WJC #292
Lincolnwelding is offline
post #2 of 8 Old 09-14-2013, 11:11 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Are they talking about the splines on you Driveshaft or your axle shafts? If the splines on the axle are shot, it likely means that the splines on the side gears/spider gears (part #16) are in need of replacement as well. Be a great time to upgrade to a locker or depending on how you wheel and tire size, a more stout axle.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #3 of 8 Old 09-14-2013, 11:45 AM Thread Starter
Lincolnwelding
Well i currently have 35x12.50s and stick to mud pits and country trails that are mostly just good for the views. I was thinking about getting either a limited slip, or selectable lockers once i go to 33's. Regearing would cost alot more money right? I know you didnt suggest it but its something i want to do in the long run anyways.
Btw i bought this jeep with no knowledge and didnt realize all the advice the original builder went against. Luckily he didnt go much farther then rims/tires and the lift.
WJC #292
post #4 of 8 Old 09-14-2013, 11:51 AM Thread Starter
Lincolnwelding
And about the axle or driveshaft part, im not entirely sure. I thought he said axle. Do you know if the mechanics would come across both splines during the install of the sye and rear driveshaft? I assume they would
WJC #292
post #5 of 8 Old 09-14-2013, 06:54 PM
schitzangiggles
King of Macastan
No reason to open up the rear diff just to bolt on a drive shaft.
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #6 of 8 Old 09-14-2013, 07:18 PM Thread Starter
Lincolnwelding
Alright sweet. I'll look into the driveshaft splines more. Thanks for your help!
WJC #292
post #7 of 8 Old 09-14-2013, 07:44 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
yes, if all it was was an SYE then it is the drive shaft splines. what shaft did you use for your SYE, as it would have required a new/different drive shaft other than stock?
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #8 of 8 Old 09-14-2013, 08:04 PM Thread Starter
Lincolnwelding
I got the rough country cv driveshaft because when i bought the jeep the rough country sye came along with it and i didnt want to worry about different brands not fitting. If it breaks im going for a tom woods sye and driveshaft im pretty sure.
WJC #292
