My mysterious ZJ - JeepForum.com
post #1 of 13 Old 10-12-2013, 03:20 PM Thread Starter
mnkjoe
My mysterious ZJ
so heres the deal 1997 zj with the 5.2. On the coldest of the past few (about 45 - 50 f) days the truck has died right after start. this has been a recurring problem ive been chasing for about a year now. ive replaced the idle air control motor and the throttle position sensor and ive also done a thorough cleaning of the throttle body but the problem still persists and its driving me insane.
But it will run if i give it gas after turning it on and after driving it a little bit it will stay running if i don't hop of the gas in 1st gear. after running for a bit it will stay running but will remain finicky.
So if you guys have any leads for me to chase it would be greatly appreciated.
Thanks again
Joe
mnkjoe is offline
post #2 of 13 Old 10-13-2013, 06:27 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
When's the last time it got a full tune-up?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 13 Old 10-14-2013, 10:33 AM Thread Starter
mnkjoe
ive replaced the plus in the past 2 yrs its got a new filter. ive cleaned the throttle body out really well. what else am i missing that could do it some good?
mnkjoe is offline
post #4 of 13 Old 10-14-2013, 10:36 AM Thread Starter
mnkjoe
Also it has had a new fuel pump in the last 1.5 years so its got a good filter to.
mnkjoe is offline
post #5 of 13 Old 10-14-2013, 04:27 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Wires, cap and rotor? How many miles were driven in the time period on the plugs?
post #6 of 13 Old 10-14-2013, 04:42 PM Thread Starter
mnkjoe
havent done the wires or cap and rotor and maybe about 15 to 20 thousand
mnkjoe is offline
post #7 of 13 Old 10-14-2013, 04:43 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Due every 30K. FWIW.
post #8 of 13 Old 10-14-2013, 04:46 PM Thread Starter
mnkjoe
sounds like they're due. whats fwiw?
mnkjoe is offline
post #9 of 13 Old 10-14-2013, 05:12 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
For What It's Worth.
post #10 of 13 Old 10-14-2013, 07:21 PM Thread Starter
mnkjoe
well i just finished it all up and it seems to idle a bit nicer but not a huge difference, time will tell. but the contacts on the inside of the cap were very corroded as was the rotor itself so those needed to be replaced regardless. so thanks for that heads up. but im not convinced this will fix my problem, got any other speculations of what it could be?
mnkjoe is offline
post #11 of 13 Old 10-14-2013, 07:29 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Did you replace the wires?
post #12 of 13 Old 10-14-2013, 08:18 PM Thread Starter
mnkjoe
i did indeed
mnkjoe is offline
post #13 of 13 Old 10-15-2013, 12:15 PM
pstewart
I had a little bit of the same issue with my wife's durango, it would start up and idle high then low then eventually stall out. However it showed a code for the crankshaft sensor. Thirty bucks for the sensor and it idles great. Good luck, maybe this helps.
pstewart is offline
