My 99 XJ is getting terrible gas mileage - Page 2 - JeepForum.com
post #16 of 22 Old 06-30-2013, 03:50 PM Thread Starter
Charley3
How about a Hesco 62mm TB with Hesco 62mm spacer?
Warning: I often edit my posts a few times to get them complete or correct errors.
Note: I had heart surgery Mar 2016. I wasn't feeling well since, but I improved this Dec 2016. Now I'm feeling better and getting back to Jeeping, modifying and wheeling.
Charley3 is offline
post #17 of 22 Old 07-01-2013, 07:30 AM
Evildriver-3
Im a F&B user when it comes to TB's, but the hesco tb would help, not sure how the spacer would really effect anything in f.i. i never seen a diff on my jeep when adding plates for other issues beneath my f&b
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #18 of 22 Old 07-19-2013, 10:40 PM Thread Starter
Charley3
My gas mileage at 60 mph has improved from 16 mpg to 21 mpg. I think that's good for 30 x 9.5 R15 tires that are on the low end of acceptable street pressure.
New plugs, wires, cap and rotor didn't make much difference.
My latest tweaks were motorvac (similar idea as Seafoam), a new oxygen sensor, and a 205F thermostat. Since all 3 of those things were done at same time, I don't know how much gas mileage increase came from each mod.
I do know that on an LJ in the past I had a 205F stat put in and gained approx 2.5 mpg. So I assume that my XJ gained around 2.5 mpg from the 205F stat.
I think the other 2.5 mpg improvement is from the motorvac, the oxygen sensor, or both. Not sure.
Prior to replacing the oxygen sensor, it was tested by a Napa car care center. They told me the oxygen sensor was fine, but I insisted they replace it
Power at mid rpm has improved some too.
Charley3 is offline
post #19 of 22 Old 07-19-2013, 10:55 PM Thread Starter
Charley3
Tomorrow my cousin and I will be installing a high flow cold air intake.
I hope to gain another 2 mpg from that.
Charley3 is offline
post #20 of 22 Old 07-21-2013, 01:16 AM Thread Starter
Charley3
My cousin installed an AFE "Cold" (cooler) Air Intake with dry filter in my XJ today.
I immediately noticed it idles a little faster and smoother. Is slightly faster idle normal with a high flow air intake?
I noticed better torque at low rpm, and better torque and power at mid rpm. I didn't test high rpm.
I have not retested gas mileage yet, but I expect some improvement.
Very happy with AFE "Cold Air Intake. I'm glade I chose their dry filter intead of their oiled filter.
Charley3 is offline
post #21 of 22 Old 07-23-2013, 09:02 AM
Evildriver-3
The stat and o2 definitely helped, the afe is good for cooler air, not sure you'll see 2mpg from that, maybe some percentage of but i have never seen huge improvements there
]=Supershafts=[
post #22 of 22 Old 07-23-2013, 01:02 PM Thread Starter
Charley3
I got 1 more mpg from the AFE, and I also got better power for hills. So it's good.
The AFE flows really free. It even starts easier and idles smoother! Noticeably more mid rpm power on hills. Haven't tried high rpm.
Charley3 is offline
