My '89 XJ turns over but will not start. Replaced battery and Coil - JeepForum.com
post #1 of 6 Old 03-31-2010, 02:03 PM Thread Starter
TheGrimJeeper
So, my '89 XJ 4wd 4.0l turns over, but I am not getting a spark from my coil, even though I just purchased one brand new. I also replaced my battery with a new one. My dist. cap is clean and was just replaced before winter....I'm running out of ideas and can't find anything helpful when I search JF...Someone please help me!
TheGrimJeeper is offline
post #2 of 6 Old 04-06-2010, 01:39 PM Thread Starter
TheGrimJeeper
I replaced my coil module as well now because it appeared burnt...and still nothing. Relays are fine.
post #3 of 6 Old 04-06-2010, 02:44 PM
LJameson
check the crankshaft positioning sensor, thats usually the culprit of a no spark/no start condition.
1990 YJ
LJameson is offline
post #4 of 6 Old 04-06-2010, 03:26 PM
ajmorell
ajmorell's Avatar
x2 on the crank position sensor.
ajmorell is offline
post #5 of 6 Old 04-07-2010, 02:07 PM Thread Starter
TheGrimJeeper
okay...i located the cps...unplugged it, plugged it back in and nothing...is there a more efficient way of testing this?
post #6 of 6 Old 04-07-2010, 02:09 PM
ajmorell
ajmorell's Avatar
That's not going to test it. If it is bad unplugging and plugging it back in won't do anything. It MUST be in working order to run right and will not run without it. IIRC I think you can test the voltage or amperage but I don't remember or know off hand what those numbers should be.
ajmorell is offline
89 xj , no spark
Engine turns over but won't start 56BelAir Engines & Drivetrain 2 12-23-2009 03:31 PM
Jeep Won't Start - Cleaned connectors, charged battery ironbelle Audio, CB & Ham Radios, GPS, & Electrical 2 11-10-2009 08:51 PM
No power at all, won't start, no lights, battery is good ikkimus Audio, CB & Ham Radios, GPS, & Electrical 5 11-03-2009 06:41 PM
Engine turns over/ getting spark/ won't start mabake Audio, CB & Ham Radios, GPS, & Electrical 4 09-27-2009 12:59 PM
4.0 XJ, Started timidly this morning, wouldn't start when I left work. starter? coil? stealthes13 Engines & Drivetrain 3 09-13-2009 06:33 PM
