My 4.7L powertech seized up? running on low oil. - JeepForum.com
post #1 of 6 Old 10-04-2013, 11:01 PM Thread Starter
kinggucci
Whenever I try to start the jeep all I hear is a click from the starter. I tried to move the crank by hand but it wont move. This happened at a stop light, the car suddenly turned off by itself, no loud noise, no shaking, nothing happened. the engined just turned off and wouldnt start back up again.
I checked it for oil and there was no oil in there according to the dip stick. The car did overheat a week before this happened so idk if that was the cause of this.
What might be the problem?
Do I need a new engine?
Can I fix this myself?
kinggucci is offline
post #2 of 6 Old 10-05-2013, 06:53 AM
uberxj92
1992 XJ Cherokee
The 4.7 & 3.7 are Chrysler miracle engines. If the get hot the have tenancies to blow head gaskets easily. Usually when they get hot they drop valves. We get 1 a month at our shop.
Your description makes me think its melted. Rebuild or replace.
What year make and model?
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 6 Old 10-05-2013, 10:50 AM Thread Starter
kinggucci
its a 1999 grand cherokee. Is it easy to replace the head? I think it dropped a valve as well.
post #4 of 6 Old 10-05-2013, 07:11 PM
uberxj92
1992 XJ Cherokee
If it dropped a valve the engine needs to come out and rebuilt. The piston will be damaged. Aluminum sux sorry.
Its relatively easy to pull the heads to look. Pull the oil pan too look in there
uberxj92 is offline
post #5 of 6 Old 10-05-2013, 07:27 PM Thread Starter
kinggucci
isnt there a pipe that goes under the oil pan? Is the pipe easy to remove?
Im sure that once I remove the pipe the rest is easy to remove.(oil pan, pistons.
How much do you guys charge at your shop to rebuild this kind of engine?
Im in the chicago area.
post #6 of 6 Old 10-06-2013, 03:50 AM
uberxj92
1992 XJ Cherokee
Daytona beach Florida here avg rebuild runs $1250 this week lol. Parts prices change then our price does too. This is as long as none if the major components are trashed
uberxj92 is offline
