MSD ignition and Blaster Coil Installation - JeepForum.com
post #1 of 4 Old 07-22-2002, 10:02 PM Thread Starter
evilpsych
evilpsych's Avatar
Hey guys.. ok.. I picked up the 6A and the blaster-2 coil.. and i'm wiring this up for my 4.0 on my 93 YJ. OK.. a few questions. I've ordered the wiring harness for the YJ so I dont have to splice the wiring.
Does the Distributor have magnetic pickup? I see a wire coming from the distributor and connected to a pigtail going to the back of the engine. If it does, does the wiring kit come w/ the connector or at least a way to tell what the leads are on this connector?
The Coil doesnt have the stud for the Wire that goes between the distributor to the coil itself.. I already know I need new wires also, but what's the deal with this? Do i need to buy a stud for it?
Alright..
oh and a unrelated thing.. whats up w/ the board lately? i miss the old board that told you the newest topic for each room..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 4 Old 07-23-2002, 12:30 PM
cyan1de
This past week ive been trying to wire a holley annihilator , pretty much the same thing youll be trying to do. Well I still dont have the damn thing hooked up. I thought that the system was magnetic, but someone at holley told me that it was points. But i do have a tj and youve got a yj. Everythings pretty easy to hook up except for the wiring to the distributor, its turned out to be a real problem for me.
98' TJ 4.0L 6" lift, FIPK, K&N Exhaust, TB Spacer, Stage 2 Jet Chip, cooling mods, nerf bars, double tube front bumper, 4 auxillary lights, HID headlights, Hi-lift jack, 35" tires, etc.
I can picture in my mind a world without war, a world without hate. And I can picture us attacking that world, because they'd never expect it.
cyan1de is offline
post #3 of 4 Old 07-23-2002, 08:16 PM Thread Starter
evilpsych
evilpsych's Avatar
Ok.. mounted the unit on the fenderwell on the passenger side.. and the blaster coil below it.. had to order a conversion stud for the coil to go from the points style plug to the electronic style stud, as well as the 4.0 no-splice wiring harness so i can go back to normal if the unit dies.. only thing.. someone told me when i hookup the magnetic pickup unit to the distributor, i'm going to lose my tach. the OEM plug has 3 studs and the MSD uses 2.. so i'm guessing that 3rd one is for the tach.. couldnt I just run a wire from this 3rd stud to the 3rd stud on the other end of the pigtail?
still looking for input and your experiences installing this thingy
anyway.. i'll have pictures and sh**t up soon..
BTT
A
post #4 of 4 Old 07-24-2002, 12:00 AM
cyan1de
well hopefully you can get the MSD to work. Apparently the holey unit I bought was incompatiable with my jeeps distributor. Luckily i bought it from truckperformance.com which is a kick *** company, theyre going to refund my money. I would like to know if you get your unit working, if so i might buy a MSD. Good luck installing it, one tip that i will give you, is be careful how you cut the wires going to youre distributor, because if you cant get the unit to work either youll have to hook the wires back up how they were originally. The gauge of the wires is pretty high, so theyre small and you dont have much room to work with around there. So im just saying make sure you can hook them back up to the wiring harness.
cyan1de is offline
very simple question about ignition coil Lostj Audio, CB & Ham Radios, GPS, & Electrical 2 05-03-2009 06:44 PM
Performance Ignition coil DTorres1978 Street Jeep Forum 10 01-08-2008 02:57 AM
4.0L Ignition Coil - Which model to buy? isuace Engines & Drivetrain 1 10-01-2007 11:01 AM
PB Blaster; yet another use. rwjeep General Jeep & Off-Road Equipment 0 05-01-2007 01:04 PM
Accel Ignition Coil dcuballa Engines & Drivetrain 1 04-09-2004 08:16 PM
