MSD Ignition - JeepForum.com
post #1 of 2 Old 03-21-2003, 07:01 PM Thread Starter
Bulletproofcj7
MSD Ignition
Anyone here use a MSD type Ignition system?
I have seen the spark they provide and they are pretty impresive!
My question is, how are they installed? can they be used with the HEI ignition with the coil built into the cap?
thanks for any help!
jason
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #2 of 2 Old 03-21-2003, 07:14 PM
Gator
hey Jason,
you can run the MSD box with the HEI however to make a HEi even better, replace the cap with one of MSD's & add the external coil of theres, the Blaster 2
I've ran a MSD Box of a 4 banger, 6 cyl & a variety of V8's
on average i got about 1-3 mpgs better afterwards
there are fairly easy to install, fairly straight forward. You'll have a Red wire that goes to the battery, a black wire for ground & another wire that will plug right into the Dist by the Tach plug thats about all you'll need
unless you do the extrenal coil swap then you'll need the small pos, going to the coil & the small ground going tot he coil as well
thats about the extent of it, all the wires are on the box that you need, dont cut any off, what i did was take a small ziploc bag, roll the wires up , place inside that & put under the box when i screwed it to the fenderwell
i hope this helps & its a great upgrade, oh one more thing, you'll gain alot more throttle response, especially crawling, not alot of bogging down or flooding
good luck
Gator is offline
MSD Ignition box jake65 Audio, CB & Ham Radios, GPS, & Electrical 1 01-03-2008 07:09 AM
MSD ignition on 4.0 Matt Gertsch Engines & Drivetrain 0 02-09-2006 05:00 PM
Ignition wyrdvans Engines & Drivetrain 3 08-28-2003 05:47 PM
ignition Q's boozehound Engines & Drivetrain 3 04-01-2002 01:52 PM
304 V8 WITH GM HEI IGNITION CJ junky Engines & Drivetrain 0 09-22-2001 09:18 PM
