Quantcast mpg with 4.88 in Rubicon - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > mpg with 4.88 in Rubicon
TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-RoadGenuine Italian leather shift boots for your Jeep!
Old 02-05-2009, 11:55 AM   #1
MBRUBICON
i am going to put 4.88 gears in my 06 rubicon with the 6spd trasn and was tryin to get a idea on what my fuel economy was going to be. i have 35s
MBRUBICON is offline   Reply With Quote
Old 02-05-2009, 10:01 PM   #2
JSBlu974X4
i was about to post the same as well. also what would power be like vs stock 31s and 4.10s? i dont wanna loose my power nor RPM's be crazy
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline   Reply With Quote
Old 02-06-2009, 08:21 AM   #3
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
4.88's and 35's put you right back in the torque zone of the stock set up. They work perfectly together. increased rolling and wind resistance will hurt your milage by about -2 mpg. My guess is you'll end up with 13 mpg avg. I get around 11-14 depending on how I drive, which usually is like I stole it. Build it, and buy a $500 Honda for commuting to work.
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline   Reply With Quote
Old 02-06-2009, 11:31 AM   #4
MBRUBICON
Ya i plan on gettin the $500 honda soon
Old 02-06-2009, 12:30 PM   #5
spyder6
Just violated my Parole
spyder6's Avatar
with the pressure in my tires a bit higher than they should be and pure interstate cruising i can pull a steady 17 MPG
city though, 13-14
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 02-17-2009, 08:52 PM   #6
MBRUBICON
what pressure do u run your tires?
Old 02-18-2009, 11:33 AM   #7
spyder6
spyder6's Avatar
28 PSI generally
USAF
Blue Crush Build
Really?
Old 02-20-2009, 06:03 AM   #8
Firedog13
Firedog13's Avatar
I'm also looking to replace stock gears with 4.88s. I have 33s on a stock suspension jeep. 2.5 liter engine. Stock 5 speed. Problem now is it is incredibly weak in 5th gear. I'm told this gear selection would be better than 4.56. I too want to keep decent mpg, since it is a daily driver and the majority of the time I am on paved roads. Any thoughts? Thanks for bringing up the topic.
Firedog13 is offline   Reply With Quote
Old 02-20-2009, 07:26 AM   #9
97TJ_Jmarsh
same set-up here but with 3.75 inches of lift, any thoughts?
97TJ_Jmarsh is offline   Reply With Quote
Glock Forum
