Motor Swap - JeepForum.com
post #1 of 6 Old 03-18-2017, 08:52 PM Thread Starter
Ms261
Motor Swap
I have a 97 jeep grand cherokee 2WD 4.0 & im buying a 98 jeep grand cherokee 4WD 4.0...
The 97 motor is bad, So i wanted to swap out the 97 motor for the 98 Motor
What i wanted to no is, is there a diffrence between 4x4 transmission and a 2WD transmission?
Besides The Transfer case, will the 2WD Transmission bolt up to the transfer case?
Ms261 is offline
post #2 of 6 Old 03-18-2017, 09:47 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
The 2wd and 4wd transmissions are not interchangeable. The tail housing on the 4wd is shorter and has mounting points for the transfer case. The output shaft of the 4wd is made to go into a t-case, not a drive shaft.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 6 Old 03-18-2017, 09:54 PM Thread Starter
Ms261
So will the 4.0 motor that comes out of the 98 4x4 bolt right in to the 97 2wd
Ms261 is offline
post #4 of 6 Old 03-23-2017, 03:52 PM
lovett86
Most likely have to swap a sensor or too or maybe even just to whole intake would be easier, but I believe the block and cylinder head are both the same
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #5 of 6 Old 09-21-2017, 06:17 AM
wperryjr
I have the same question except I'm looking to put a i6 from a 98 Cherokee into an 03 grand Cherokee. Both 4x4, is this possible? One has a cap and rotor and the other don't.
wperryjr is offline
post #6 of 6 Old 09-30-2017, 07:53 PM
rjbruzan
Cherokee and 03 Grand motors are different.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is online now
