motor mounts - JeepForum.com
post #1 of 4 Old 09-12-2013, 12:08 AM Thread Starter
china
motor mounts
is there a trick to getting the left motor mount off of a 2005 jeep lib. the right one was easy but left is giving hard time.
china is offline
post #2 of 4 Old 09-12-2013, 08:27 AM
biffgnar
biffgnar's Avatar
Not sure about Libertys but on late model TJs the driver sider motor mount can be problematic if you have AC as you can't get the through bolt out. What we do is take the bracket off the block, then you are able to remove the through bolt and when you put it back together you put the bolt through the other way.
Romney in 2020!
biffgnar is offline
post #3 of 4 Old 12-07-2013, 11:45 AM
aagill225
When I first changed mine I flipped the blot so the nut is in the forward side and the bold slides toward the driver seat. Is that going to cause any issues?
'99 WJ, 4.7L, completely bone stock, except for 245/65/16 tires
'76 Jeep Grand Waggy, 360cid Edle 660cfm/edle intake Quadratrac
'02 Exterra 3.3L, 5-spd, traded YJ for it :(
'89 YJ 2.5L, 5-spd, Borla header, dynomax super turbo muffler, Big-O XT 30x9.5r15
2004 Jeep Liberty Renagade 3.8L 2wd
'86 XJ 2.8L V6, 5-spd manual tranny (My 1st)
aagill225 is offline
post #4 of 4 Old 12-07-2013, 05:04 PM
biffgnar
biffgnar's Avatar
Flipping the bolt is the correct thing to do.
Romney in 2020!
biffgnar is offline
