Motor mount question 4.0 liter conversion - JeepForum.com
post #1 of 1 Old 05-11-2004, 12:52 PM Thread Starter
yellar bellied
yellar bellied's Avatar
I've got a CJ7 that had the 4.2 and I picked up a 4.0 liter from a 2000 TJ. The problem I've run into is on the drivers side. The three bolt holes that will definantly work with my old 258 motor mounts are all on the same plane. The old motor mount has the upper one of the three in towards the engine by about a 1/4''.
The only way I see to make this work is either to space the lower two out accordingly or to cut or grind the bolt hole to allow for the old mount to be used.
I know the third hole is a metric 12mm and I also am aware of the upper hole in the mount itself requiring some drilling to enlarge it.
I'm very leary about cutting the boss on the block but am also convinced it could be done.
Anybody else run into this problem on that year of engine or similar? And what did you end up doing?
Thanks
Passenger side was a little bit of work for those that are considering this swap but not that big a deal. The mount had to be ground down somewhat as well as a 1/4" of cast on the block, but it was only a fin running along the boss.
red jeep club member #62 Flip'n'Roll Club founder member #1
OFF ROAD USER NOT ABUSER
TAKE SOME CARE SO YOU DON'T LOSE 'ER
1984 CJ 7 with OBII 4.0 liter, NV3550, ARB front, Detroit rear, 4:10's
Full cage, dual Optimas.
yellar bellied is offline
Motor mount tower/motor frame mount location pepto Engines & Drivetrain 3 03-24-2009 02:07 PM
Motor mount question 90roughcountryj Engines & Drivetrain 3 08-09-2004 12:37 AM
Motor Mount lift question?? Nymisus Engines & Drivetrain 6 12-03-2003 12:29 PM
2.5 liter upgrade question BigD1634 Engines & Drivetrain 2 09-22-2002 09:17 PM
2.8 liter and 3.4 liter harmonic balancers the same?? stvdman Engines & Drivetrain 0 02-09-2002 12:58 PM
