Motor Help (push rods) -
post #1 of 2 Old 05-17-2012, 09:03 PM Thread Starter
Ijust bought a jeep grand wagoneer this last weekend at a auction. The jeep has been sitting for 12yrs without being moved. The motor (360) was purring like a kitten. I drove it to the gas station put in 9 gallon (%91) on top of the 12yr old 7 gallons in the tank. Drove it home 8 miles, and the next morning I started it and now itís ticking on the driverís side valves.
I did an oil change then brought it home and removed the valve covers on the driverís side and found that each cylinder had a bent push rod.
I have not yet removed the cover on the other side to see if it too has bent push rods.
What could have caused one push rod of each cylinder to bend???
This may help you help me!
1 bent back rod
3 bent front
5 bent back
7 bent front
fire2fire is offline
post #2 of 2 Old 05-20-2012, 02:33 PM Thread Starter
So here is what I found.
All 8 intake push rods where bent.
After fuel sits for 12 years it turns to varnish and can hold your valves(intake) in place like it was welded. I ended up taking off the valve covers and spraying carb cleaner into the lifters and worked them in and out till free. Then I worked some marvel mystery oil in to them until operating smooth.I also replaced all 16 push rods.
What should have happened before any one even tried to start a vehicle aftersitting for years without running.
1- Empty fuel tank and have boiled
2- Rebuild carb
3- Try to turn motor by hand to see if its free, if not pull all spark plugsand put some marvel mystery oil, wait 24hrs then try again, if still frozenremove valve covers and make sure all valves are free.
Ok that’s all I have I hope this helps someone so they don't have to gothrough the trouble I did.
In order to be able to post messages on the forums, you must first register.
258 bent push rods JohnGodwin30 Engines & Drivetrain 0 08-23-2011 02:46 PM
Push rods,,,, Kinda dumb question. Rio_Grande Engines & Drivetrain 2 03-19-2011 08:00 AM
Push rods/Valves/lifters...Chatter/tappy/when rev Splug Engines & Drivetrain 5 09-05-2009 06:02 AM
258 4.2L Bent Push Rods pats010304 Engines & Drivetrain 0 03-21-2005 05:34 PM
8 BROKEN PUSH RODS!!!! Jami Engines & Drivetrain 3 05-29-2002 03:40 PM
