most cost effective way to swap a v8 - JeepForum.com
post #1 of 7 Old 11-17-2012, 09:52 AM Thread Starter
zackyv
hey guys im new to here an was wondering whats the best an cheapest way to swap a v8 into a 94 yj that had a 2.5l an a 5 speed an im on a highschool budget tganks
zackyv is offline
post #2 of 7 Old 11-17-2012, 10:24 AM
mig1289
Most cost effective way is to sell the 4 banger and buy an 8 cylinder.
2wd zj...
mig1289 is offline
post #3 of 7 Old 11-17-2012, 11:55 AM
ltrail
1984 XJ Cherokee
Find a wrecked vehicle that has all the necessary amenities and part out the pieces you don't need. Its expensive either way you go really. I bought an 89 Chevy 1500 and parted it out. My drive train was essentially free afterwards, however I had to rebuild the engine and trans and im about 1500-2000 into it.
You will want to find a set of axles to keep the additional power happy. Stock rear end won't last long. At least wouldn't in my high school budget days.
Don't overlook the 4.3L s10 engine either. Its a good unit, and a 4wd s10 can be had reasonable. A buddy picked up a wrecked 95 s10 blazer for less than $1000. There's your engine, trans, case, wiring and what not.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #4 of 7 Old 11-17-2012, 01:26 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Yep, I agree, get the complete donor vehicle or at least the complete drivetrain + computer(s).
Adapters and custom wiring harnesses are expensive, so avoiding using them can save you some money.
Wheelin98TJ is online now
post #5 of 7 Old 11-17-2012, 05:46 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
I use a complete donor S10 when I can.
Zero adapters etc that way.
My thread has the part numbers for everything you would need like hoses etc.
You can reuse your harness, or get a Painless one etc, your call.
Last one I did would have cost @ $1600 for the swap, if he knew what he was doing and did not rebuild the engine, tranny, etc.
Instead he paid me to do it all!
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #6 of 7 Old 11-17-2012, 07:41 PM
ltrail
1984 XJ Cherokee
Ha, the only reason I got the vehicle so cheap was that it had 328k on it and finally blew head gasket. Figured if I was rebuilding the engine I didn't want my tranny to be a weak link so I followed suit with the rest. Part of my cost was steel to plate the unibody so i didn't end with a crumpled beer can in the end. You can skip that portion since your rig has a real frame.
You won't realize it until its too late but all the small things will cost you a load of money. Exhaust, wiring, radiator, fans. I am using every last bit of the truck that i can. Slightly regretting it now but i sold off my exhaust for scrap since the guy offered a fair amount for the catalytic converter.
One other small bit of help, keep the jeep complete until the bitter end. Have the engine and what not out and ready (from donor vehicle) and keep jeep whole as long as possible. Few things that will help as you have time to part out your other vehicle to have some spending money for the swap. And you still have the jeep to drive and if you plan on selling the 4cyl buyers like to see the engine run before buying.
ltrail is offline
post #7 of 7 Old 11-19-2012, 05:07 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
You're not going to like this.....
Sell what you have and buy one with a 4.0
Quick, easy, and very little mechanical knowledge required. Keeps the fab skills to a minimum as well.
If you take your time, the cost should be little to nothing.
jeepdaddy2000 is offline
