Mopar Performance Parts Camshaft - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Mopar Performance Parts Camshaft
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge BushingsStainless Steel Door Hinge Pins
Unread 03-23-2003, 11:11 AM   #1
GetonYourMark
I have found a Jeep dealer offering to sell this cam package for under $30:
Camshaft packages for 2.5L 4-cylinder applications. Includes camshaft, tappets, assembly oil and instruction sheet.
Has anyone replaced their cam? Is this difficult? What other parts are needed? And what has been your experience with the performance?
Thanks
'00 TJ, 2.5L, 5psd, 4.10's, TB Spacer, K&N, 2" lift, KC's, 32x11.50 MT/R's, AR767's
'02 Liberty 4x4 Sport, 3.7L Auto, bone-stock
GetonYourMark is offline   Reply With Quote
Unread 03-23-2003, 01:12 PM   #2
BamaJeeper
Thats a hell of a deal! I have one in my 94YJ 2.5L and I have been impressed with. I got the.440 lift/248 duration cam which gives the motor more torque in the low rpm range. This cam is great for when I'm going really slow on the trail and the motor does'nt bog down like it used to.
Installation took about 6 hours of actual work but I took my sweet *** time with it over two days. You will need a few other parts to do this mod.
Timing cover gasket kit.
RTV
Razor blades to scrape off old gasket.
Harmonic balancer puller. Rent it at Autozone
Extendable magnetic pick-up tool. For install/removal of lifters.
Valve cover gasket.
Brake cleaner to clean the gasket surfaces.
Coolant
It's not a difficult mod.
Out of the darkness comes light.
BamaJeeper is offline   Reply With Quote
Unread 03-24-2003, 09:28 PM   #3
BigD1634
2008 KK Liberty
your cam
I am thinking of getting a mild cam for my 2.5L (1995), but I have to pass New Jersey Emmisions which are pretty strict. how does it actually perform. From a start?, on the highway?, and just cruising? I do a lot more on road then off. Thanks
BigD1634 is offline   Reply With Quote
Unread 03-24-2003, 10:42 PM   #4
Quan
anything like that for a 4.0? I'm pretty sure it would void my warranty for the rebuilt but i could plop it in after the warranty is up while i wait for 350 day!
[b]There comes a time... In every mans life, when decisions... have... to be made. Whether to toil, to labor, or just plain piss your days away.[/b]
[b][COLOR=green]Green[/color] Jeep Club Member #15[/b]
[b]My Jeep Made Me Broke Club Member #2[/b]
93 YJ I-6 w/ stuff
Keep the [COLOR=blue]greasy[/color] side down
[URL=http://members.cox.net/quanno/ford88.html]FORD 8.8 INFO HERE![/URL]
Quan is offline   Reply With Quote
Unread 03-25-2003, 01:57 AM   #5
BamaJeeper
It helps more from a start. I noticed greater power from 500rpm-2500rpm. After 2500 rpm I can't tell a difference on the trail but on the street you don't won't this cam for long commutes to work.
Unread 03-25-2003, 01:58 AM   #6
BamaJeeper
They do have cams for the 4.0L. How much longer on your warranty Quan?
Unread 03-25-2003, 02:17 AM   #7
GetonYourMark
BigD1634--
I don't know if a cam alone would affect your ability to pass emissions testing, however on the Mopar website it does say:
*Not legal for sale or use on pollution-controlled motor vehicles
As far as performance, the website says it is for mild competition and is for the 1100-4800 rpm range.
In general, higher lift, longer duration cams add power and torque, two very good things.
Quan--
Mopar makes three performance cams for the 4.0, this is the info from their website, with the parts numbers for each. Just call your dealership with the part number for their price.
Part Number Advertised Duration O-Lap Center Line Lift Basic RPM Recom. Spring Applications & Comments
*P4529228 240/240 24 108 .430/.430 900-4700 P4529214 Mild. Comp
*P4529229 248/248 32 108 .440/.440 1100-4800 P4529214 Mild. Comp
*P4529230 256/256 40 108 .450/.450 1300-4900 P5249464 Mild. Comp
I am thinking of having the dealership install it, and take advantage of warranty protection etc., however if they say it is not legal for sale or use, I'm not sure if the warranty would apply, and even if they WOULD install it.
For $29.96 (for my application) I'm gonna buy it and if it sits in the box for awhile until I try it, or find the right guy to do it, it is ok.
Unread 03-25-2003, 06:39 PM   #8
old_man
I put one in my XJ and it passed Colorado emissions with flying colors.
Tom Houston
Loveland, Colorado
old_man is offline   Reply With Quote
Unread 03-25-2003, 06:52 PM   #9
BigD1634
2008 KK Liberty
colorado emmisions
What test do theyt do in colorado. We do a 50/15 test on a dyno.
Unread 03-25-2003, 08:45 PM   #10
old_man
Where I live in Colorado, they just do a tail pipe sniffer. I have no question that it would pass. It just runs too well. On the tailpipe sniffer it was about 20% of the limit. They check at an idle and at some accelerated rpm around 2500-3000.
Tom Houston
Loveland, Colorado
Unread 03-30-2003, 06:13 PM   #11
wrangler john
I have one of those 2.5 liter cams in my 95 wrangler. Passed Delaware emissions with flying colors. Now granted the engine is freshly rebuilt, but you should not have any concerns about passing emissions testing. I did not get to drive before replacing the cam, but engine is very torqy in the lower rpm range. You should be happy with it. I got mine from Koller dodge off of ebay for just under $70 + shipping.
Some people thing 1 jeep is enough, But I had to have 3!!!
wrangler john is offline   Reply With Quote
Unread 04-01-2003, 08:43 PM   #12
JeepN2
Thanks All for the info..I just purchased a HP cam for my 2.5L off ebay also. Think he has a few more for sale on the site if interested.
Looking forward to the installation..
Later
JeepN2 is offline   Reply With Quote
Unread 04-01-2003, 08:55 PM   #13
BigD1634
2008 KK Liberty
delaware emmisions
What kind of testing does delaware do. Jersey does a 50/15 dyno test. they run the jeep on a dyno at 15 mph for 30 seconds to test for emmisions. What size cam did you put in. Did it effect your brakes at all.
Thanks.
Unread 04-02-2003, 02:31 PM   #14
wrangler john
Here in DE they sniff the tailpipe @ idle. They have not yet gone to dyno testing like you have. The cam that I have is not a wild cam at all, basically what I would call a "RV" cam. I have the tag off of the box at work but not able to access it now. brake vacum is not a problem. the cam is not that wild at all.
Unread 04-18-2003, 08:56 AM   #15
allaboutjeep
just searchin through old posts and found this, what was the affect on gas mileage?
93 yj , 2.5L , 2.5in lift+ .75"shackles, 4.0L TB+ spacer, custom intake, K&N filter, high flow cat, turbo muffler, custom tailpipe, flush LED's, electric fan, and more...
allaboutjeep is offline   Reply With Quote
