MJ clutch master cylinder/no pressure - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > MJ clutch master cylinder/no pressure
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineXJ guys, clock your transfer case!Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!
Unread 11-26-2008, 08:02 PM   #1
mxsuz238
Bought an 86 comanche off my buddy and the clutch master cylinder was off, he said it was leaking. Installed one this evening and put fluid in the reservior and pumped the clutch pedal 50 times maybe and the fluid level had barely gone down. added some and same thing.I traced the hose back and found no leaks. I'm still getting no pressure on my clutch. AM i overlooking something? The fluid line coupler is tight on the master cylinder and the arm to the clutch pedal is on.
mxsuz238 is offline   Reply With Quote
