Misfiring 4.0 - JeepForum.com
post #1 of 17 Old 01-15-2006, 03:00 PM Thread Starter
willy peter
Misfiring 4.0
I already posted this in the TJ forum, but I thought I might get more/better responses here. So for about the last week I've had the check engine light on telling me that cylinder #5 is misfiring. It would only happen under real heavy acceleration. Well, Friday the 13th comes around and guess what, it know does it constantly and my jeep is undriveable. I believe it may be clogged or dirty injectors from a bad tank of gas. I will be replacing them ASAP. Has anyone else had this problem and/or do you think this will fix it. BTW, only 32K miles.
Plugs were replaced 2K ago with champion truck plugs. There are no plug wires on a 2001. I think I can rule out any spark related problems.
Steel Blue 2001 TJ Sport
D44/D30 with 3.73's/31x10.5 Kumho AT's on stock canyon's/Rhino-lined interior/Alpine 9856 Headunit with Infinity speakers/Teraflex disco's/Blacked out headlight bezels/Removed front flotation devices!
Planning on more, just saving up the cash.
willy peter is offline
post #2 of 17 Old 01-15-2006, 03:32 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Its a pretty common problem on the 00-01 XJs too. Call the dealership and see if you have any outstanding recalls. There was a heatshield recall on the XJs.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #3 of 17 Old 01-15-2006, 04:15 PM
bobjp
What makes you think you got a bad tank of gas? That would effect all of the cylenders not just number 5 I would think.
bobjp is offline
post #4 of 17 Old 01-15-2006, 07:05 PM Thread Starter
willy peter
I have heard about adding additional sheilding to the #3 injector but not #5.
post #5 of 17 Old 01-15-2006, 07:07 PM Thread Starter
willy peter
I have friend who got gas from the same place about the same time and his car wouldn't start until he diluted it with a lot of new/different gas. Unfortunate he only got about 5 gallons whereas I got 15. I think it started with #5 but will spread to all of them eventually.
post #6 of 17 Old 01-15-2006, 07:43 PM
bobjp
Have you tried diluting your gas? Or maybe drain it out and putting some new gas in. Check out your fuel filter. See if it is filled with gunk; if it is then it may have let stuff pass into your injectors. There are products that you can buy that will clean your injectors. I used some stuff from napa that came in an aerosol can. You spray it right in the injectors when you take them off.
I am unfamiliar with the ignition system of a 2001 4.0. You say it doesn't have plug wires? What kind of ignition system does it have? Do you have a chiltons/haynes manual for it. I have a Haynes manual for 87-2003 wranglers and it doesn't say anything about the 2001's not having plug wires otherwise I would look in it for some info for you.
bobjp is offline
post #7 of 17 Old 01-15-2006, 08:18 PM
Snuffster
'00's and up use a coil pack ignition system (much better when you blast through water lol). The problem could be a bad coil pack. They do go bad. It is easy to test, but too much for me to type. I will say you need an ignition system tester, a jumper wire and you have to remove the coil rail. A Haynes manual details it step by step. I think bad gas is out of the question.
'01 Wrangler Sport 4.0l, 4 inches and 33's
'99 Trans Am 427ci
'05 GTO stock
Originally Posted by LandRover
That was my master's degree talking.
Snuffster is offline
post #8 of 17 Old 01-15-2006, 08:21 PM Thread Starter
willy peter
I will look into that, is it common for them to fail this soon?
post #9 of 17 Old 01-15-2006, 08:29 PM
Snuffster
*edit* Nevermind, you know you have a #5 misfire. I'm betting it's a bad coil pack or injector.
'99 Trans Am 427ci
'05 GTO stock
post #10 of 17 Old 01-15-2006, 08:31 PM
Snuffster
I don't know if it's common, but it is not unrealistic.
'99 Trans Am 427ci
'05 GTO stock
post #11 of 17 Old 01-15-2006, 08:45 PM
Snuffster
One option is to swap the #5 injector with another one and see if the same cylinder is misfiring. If not, switch coil packs around.
'99 Trans Am 427ci
'05 GTO stock
post #12 of 17 Old 01-16-2006, 01:53 PM Thread Starter
willy peter
OK, I got a new injector to try, but now I'm trying to reinstall the fuel rail. I can get all of the injectors to fit snug in either the manifold or the rail, but none of them will snap into both the manifold AND the rail. I have lubed all the o-rings, and applied superhuman strength. What else do I have to do?
post #13 of 17 Old 01-25-2006, 10:42 PM
stonehogg
How Come Your Engine Light Is So Smart It Can Tell You Which Cylinder Is Misfiring ? No Body Elses Is....
stonehogg is offline
post #14 of 17 Old 02-03-2006, 07:51 AM
WVMIKEsTJ
Same prob!
Mine is doing it to!! I changed plugs and that worked for a few days and then poof the light was back on. Went to the dealer and the mechanic told me and showed me that # 5 is misfiring. I was watchiong it misfire on their computer. What next?
WVMIKEsTJ is offline
post #15 of 17 Old 02-03-2006, 09:37 AM
98JEEPTJ
2005 WK
I have a stupid question for you guys. Are you using the correct plugs?? Are you sure you got the correct plugs from the parts store. I had a dude give me five correct plugs and one that was to long. Thus the piston hit the plug just enough to bend over the electrode so it wouldn't fire. it was cylider #5. I couldn't figure it out until I pulled all the plugs and was inspecting them and see this one all bent and mangled. I was pissed. The dude at oreillys just said oops. So I talked to the manager and he paid for the Shop to look at the pistons and head to make sure there was no damage...I was pretty scared when he said that they had bought people engines in the past because they gave them the wrong parts...Yeah I don't go to that store any more....
OUT WITH THE OLD R.I.P. 98 TJ Sport 4" Procomp lift/adjustable lower control arms and track bar **** Cepek FCII 33x12.50x15/**** Cepek DC-1 wheels
IN WITH THE NEW 05 WK LIMITED EDITION 5.7L
98JEEPTJ is offline
4.0 ticking and misfiring at certain RPM dennisM83 Engines & Drivetrain 5 04-12-2010 07:20 AM
4.2L Misfiring Under 1500 RPMs Tshark299 Engines & Drivetrain 2 01-09-2005 09:22 AM
